New Member: Calling Bagged Subs/Panels and anyone running 20's (tire Q)
Hey Guys,
Finally ready to start completely redo'ing my chopped '55 suburban I started 20 years ago and finished about 15. Looking to bag it, new wheels, new interior for now...then will go to the motor again and do a turbo LS most likely. Most of the things I wish I had done by the time I was done with the project, but just weren't happening when we started in '95. Have a few questions: 1. Any bagged sub/panel guys here who can show me how you did the back floorboard when completed? One thing I can't lose is back seat space and that's a concern of mine. This thing has two kids seats in it at all times for my 2 and 4 year old (this is the car I got to keep when the kids came)....and my wife uses it for grocery store runs, etc so I can't lose a ton of space. 2. Looking to go 18's upfront and 20's or 22's (most likely 20's) in the rear. The car is tubbed so I can get quite wide but don't want a super low profile sidewall. When we first built it, it was on if I remember 305/50r17's (which they no longer make, so i'm stuck on 285/60's). But I wanted tos ee if anyone is running a 305/45r20 and could show pics, or a 315/35r20.
Chopped '55 Suburban "subhuman" |
Re: New Member: Calling Bagged Subs/Panels and anyone running 20's (tire Q)
Also, i'm debating between the Billet Specialty Bonneville G's or the SLD89's. These two have been in my head for almost a decade and I just need to pull the trigger. My boyds are trash, 2 bent, 1 out of round, other one won't balance for sh*t.
I had planned on bagging it first, but the shop I want to do the work is booked up till fall. So I'm going to do wheels first. ![]() ![]()
Realize those aren't the bonnevilles, but the Heritages. Also looking at the heritage S's:
![]() Join Date: Jul 2012
Well, I haven't made a wheel selection yet and my Burb is a 48 on bags. I don't know if 20's will fit, though you could take a peak at how I did my floor. I only used a c notch in the rear instead of a kick up. So much yackity yack in my build thread..my fault...you could start at the end and go back a few pages.
Probably someone with a Task Force Burb will weigh in. Chizzler built a very cool AD Suburban with a kick up. He may chime in and I will look for his thread. Youngrodder is going the Porterbuilt route on his AD Burb and has a good build thread going. http://67-72chevytrucks.com/vboard/s...d.php?t=404091 |
Thanks bud. Will take a peak. Chizzlers burb is exactly what id do if I did this one over again.
Appreciate the response brother.
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
On my burb we made the rear floor section out of metal. Im running 6.70-15 firestone white walls.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
I haven't dug through the pics yet. How far up did you have to come? Is it flat all out back?
Here is what it looks like.
Right on. Thanks for the pic!
Here is what I did. Added 3 1/2 inches width to the tubs and built the bubble in the middle of the floor for differential clearance when aired out.
I like that. Could get away with that one!!!
A seat will fit over the bubble and I am not going as low as Chizzler. Just a c notch in the frame.
I believe this one was built with a C notch. The builder also built my chassis. http://www.tricktrucknrod.com/hh/Pro...?productId=247 |
Hey HB,
This is what I'm doing. I replaced the floor with new wood. Thought Id just make the hump with wood but really didn't like that look. I had a sheet metal piece made but have to put it in when it warms up. The photo is just to give you some ideas... |
![]() Join Date: Jan 2015
theses are a tad bit wider the the 305's but 18's and 20's
#15 |
#16 | |
dig it, i built out side compartments (one side holds two batteries, the other a compressor, and then storage above). I think i can get away with moving the floor up 12-18". Just need to keep it flat as this thing gets filled with all types of random junk.
