![]() Join Date: May 2014
5/8 static drop parts list comments/suggestions please
Here is my list and a few questions I have. Going for a 5/8 static drop.
I'm currently running a 6cyl with three-on-the-tree but I want to make it handle and one day will do a LSx swap so I might go a little overboard here in preparation for later. Planning on running 15 steelies so I am limited to smaller brakes. I want to buy everything ahead of time to minimize downtime, so if there is anything I have missed please let me know. 1. CPP Modular 2 Drop Spindles 2. 3 drop springs (any brand?) 3. Tubular control arms (CPP?). I suppose I only need the uppers to get the improved adjustments (or is it the lowers?) but Ill probably do both for the looks. 4. 12 disk brakes (will these fit in my 15 steelies? Is this as large as I can go?). Do people usually buy kits from CPP or somewhere, or just buy stock stuff from regular auto suppliers.? What little pieces/kit will I need to have everything? 5. Power brake booster (which one?). Thinking Ill go fairly stock right now for disk/drum combo. I will likely upgrade to hydroboost when I do the LS swap. 6. Wilwood adjustable proportioning valve http://www.summitracing.com/int/part...1179/overview/ 7. Stock-style master cylinder (which bore size for disk/drum?) 8. New front brake lines (where to buy?) 9. Front sway bar (any brand?). Want to match with nolimit rear bar. 10. Front shock relocate brackets? 11. Shocks - looking for good/great handling at medium price (what brand and what length/part number.?) Im choosing modular drop spindles because they keep the wheels tucked in better and should look more 1967-like. They may also allow a little more clearance with my 15 rims (dont know if this is true). I want Wilwood adjustable proportioning valve because it sounds like the stock replacement ones are junk and I only want to do this job once. Will I need custom brake lines for it.? Or should I plan on bending some lines? Do I need new brake lines 1972-style (in front of crossmember) instead of my 1967-style (behind crossmember).? Can I buy normal length front shocks if I use a relocate bracket.? If I buy new control arms to go with modular spindles should I specify newer ball joints or stay 67 throughout.? On the rear I want an 8 drop. Planning to use 2 blocks and 6 lowering springs along with No Limit panhard, sway bar and shock relocate kit. Matching shocks to front of truck. And a c-notch of course. If I have missed anything Id appreciate knowing about it. I want to have all the parts in hand before I start tearing the truck apart because I like to keep the downtime to a minimum.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
Re: 5/8 static drop parts list comments/suggestions please
Have you considered pancaking your crossmember for a 1.5 inch drop, and much need ground clearance?
While at it you could change your a arm relationship by moving the lower arm forward 1 inch to get better camber gain. |
I'd like some clearance..!! I have another low low car and I'd like a bit more clearance with this one so I can drive it harder without hitting the ground.
#4 | |
I was seriously looking at doing a nolimit dropmember or a porterbuilt but I want to keep driving my 6cyl for a while and didn't want to do a bunch of mods. (I don't mind mods that will carryover to my LS swap but I don't feel like doing a lot of extra work just to keep my 6cyl running. My priority right now is to get it low and keep driving it. Probably won't get around to the LS swap until winter 2015/2016)
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" Last edited by kitsbeach; 03-02-2015 at 02:11 AM. Reason: clarifying |
Pancaking/sectioning the x-member can provide drop w/o changing the OE motor location. The easiset way is taking the section out across the entire x-member which allows using the OE MM towers & such. The alternative is simply notching out the x-member directly below the frame rails, dropping the section down further, & welding/boxing it back in. This method will require modifying the MM towers which could change things if not done w/moderate precision. Either way will possibly require modifying the upper arm or changing to different steering shaft linkage as there can be interference @ the front of the a-arm (definitely w/aftermarket arms).
1,2,3) The modular spindles are a good choice as they're adaptable to bigger brakes in the future. Get BJ's recommended for the spindles. For springs I would do Hotchkis or Moog for a BBC & trim them down. The CPP arms don't do much of anything so they're basically an added expense. Hotchkis arms would yield some geometry improvements & would prob be the better choice (especially if utilized w/their springs & shock combo). If Hotchkis parts are too much for the budget (they are very high priced IMO), stick w/OE arms & do the caster mod discussed in the 'Make It Handle Thread'). 4) 12" disc brakes work fine w/15" wheels built for disc brakes. OE 5-lug wheels were most likely on a disc brake truck. Drum brake truck wheels will not clear. 5,6,7,8) Factory replacement 71-72 disc brake stuff would work fine. CPP has a kit as well. The adj prop valve is a good idea especially if 4whl discs are in the future. New brake lines will be necessary (although there might even be a kit that caters to not having to replace them). 9) OE 3/4 & 1-ton 1.25" GM truck/Suburban front sway bars have been working for years w/o issue & are cheap. Or, Bell Tech offers a big bar @ a decent price through Summit Racing. 9,10) Front shock relocation brackets are a good idea. You want to keep the shock stroke as long as possible for best ride quality. Bilstein makes a great quality shock as well as QA1 or Ride Techs brands (the latter choices being adjustable too as upgrades). One-stop shopping, for a packaged assembly that flat out works, I would do Hotchkis hands down over CPP if it's within the budget. Otherwise stick w/OE arms & educate yourself.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-02-2015 at 03:14 PM. |
#6 | |
Hey SCOTI thank you for your response. Exactly the type of info I was looking for. I was under the impression that CCP control arms gave us the caster improvement. If they don't then I will scratch them off the list or look for a better alternative. I have new wheel vintiques 62 series, so they will fit the disk brakes. I actually tried to buy used but they are so rare now and rusty that I ended up doing a lot of driving and craigslist searching with no luck (have one drum brake style rim). And I'm thinking the sectioned crossmember is just too much work right now.
#7 | |
Hey SCOTI it looks like the CPP arms do add some caster. Here is what they say on their website:
67-72 parts collector,
![]() Join Date: Nov 2002
3" drop coil = 3" shorter shock of you are using the stock upper mount.
I thought the front upper shock "relocation" bracket allowed the use of a stock shock, since it places the mounting point farther apart. Porterbuilt sells these too and matching shocks. I use Belltech or McGaughys or Western Chassis or ECE for drop coils.
A day late and $1 short...
My 2’...
1. CPP Modular 2 Drop Spindles Good choice! 2. 3 drop springs (any brand?) I like Early Classic Enterprises (ECE)springs as they are thicker and therefore give a more controlled feel, CPP are spongy in my opinion. 3. Tubular control arms (CPP?). I suppose I only need the uppers to get the improved adjustments (or is it the lowers?) but Ill probably do both for the looks. CPP are fine but I would buy Porterbuilt (PB) Forward arms; they center the wheel in the opening as well as correcting the geometry. You can just buy lowers if you want to save some cash. 4. 12 disk brakes (will these fit in my 15 steelies? Is this as large as I can go?). Do people usually buy kits from CPP or somewhere, or just buy stock stuff from regular auto suppliers.? What little pieces/kit will I need to have everything? You can buy the rotors and calipers from your local part store (I asked for 73 Chevy parts). These will work with your 15 wheels. You can get conversion brake hoses (ECE part #03-6480) that connect your factory hard lines to the disc brake calipers. 5. Power brake booster (which one?). Thinking Ill go fairly stock right now for disk/drum combo. I will likely upgrade to hydroboost when I do the LS swap. The CPP disc/drum booster/master kit (part #6772BB2) will work fine. 6. Wilwood adjustable proportioning valve http://www.summitracing.com/int/part...1179/overview/ Nice piece if you want to spend the money. 7. Stock-style master cylinder (which bore size for disk/drum?) Answered in #5. 8. New front brake lines (where to buy?) My experience says build them to fit. 9. Front sway bar (any brand?). Want to match with nolimit rear bar. Addco makes on to work with the PB forward arms. 10. Front shock relocate brackets? Not necessary in my opinion but PB makes them if you want them. 11. Shocks - looking for good/great handling at medium price (what brand and what length/part number.?) Here is where you can greatly enhance your handling, spend the money on GOOD shocks. I would suggest RideTech HQ series single adjustable units. You can adjust the rebound to fit your driving style. The tough part is I imagine they are over $700 for a complete set. Im choosing modular drop spindles because they keep the wheels tucked in better and should look more 1967-like. They may also allow a little more clearance with my 15 rims (dont know if this is true). Makes sense to me. I want Wilwood adjustable proportioning valve because it sounds like the stock replacement ones are junk and I only want to do this job once. Will I need custom brake lines for it.? Or should I plan on bending some lines? Id plan on bending some, the aftermarket lines I have encountered where not worth the money because they didnt fit. Do I need new brake lines 1972-style (in front of crossmember) instead of my 1967-style (behind crossmember).? ECE conversion hoses will work with your existing hard lines. Can I buy normal length front shocks if I use a relocate bracket.? Call RideTech, they will hook you up. I think member crawdadfox is a dealer and may be able to help you with these. If I buy new control arms to go with modular spindles should I specify newer ball joints or stay 67 throughout.? Id stay 63-70 ball joints, if not youd have to change many other steering and suspension parts. On the rear I want an 8 drop. Planning to use 2 blocks and 6 lowering springs along with No Limit panhard, sway bar and shock relocate kit. Matching shocks to front of truck. And a c-notch of course. Seems reasonable to me.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#10 | |
The ECE conversion hoses will be a lifesaver because my truck appears to have newish brake lines and this way I don't have to replace them. But I may have to do something up top since I'm changing form manual to power brakes and I am planning to use the Wilwood proportioning valve. And a couple votes for the PB forward arms so far (and they are roughly the same price as CPP).
Here is a static 5/7 drop set up I've been wanting to see someone build.
Front Porterbuilt Upper and lower control Arms - 1’ forward for coil spring ($1098) CPP Modular Spindles – 2” drop ($299) ECE Front Drop Coils – 3” drop ($114) CPP Tie Rod Adjusters ($69) ADDCO Sway Bar ($249) RideTech HQ Series single adjustable front shocks ($350) Rear Porterbuilt Stage 2 deluxe for static drop: Porterbuilt Trailing Arm Crossmember ($249) Porterbuilt trailing arms with spring mounts (1” drop built in) ($499) ECE Rear Drop Spring – 6” drop ($114) Porterbuilt adjustable rack bar ($199) Porterbuilt C-notch ($279) Porterbuilt Upper/Lower shock mounts ($200) (need to check with PB on this cost) RideTech HQ Series single adjustable rear shocks ($350) Rear Sway Bar - TBD not available from PB but lets say it costs ($250) Total Cost around $4319 (plus shipping) I think this would be a fantastic street truck set up. The shocks would go a long way toward tailoring the ride quality and performance and the other parts would partener to make the truck handle very well. Wouild love to see someone do this.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 03-25-2015 at 08:59 PM. |
#12 | |
And I will keep my stock trailing arms. Will check pinion angle and maybe flip the mounts if I can get away with it.
#13 | |
I updated my original post with prices from each companies site. Looks like the total is just over $4300 plus shipping. I'm sure Dave at Porterbuilt could create a kit for this set up and provide all of these parts in one effort. Porterbuilt doesn't currently offer a rear sway bar but word on the street is there are plans to begin development on one, so the price is a wag.
#15 |
Buck, ECE doesn't make a 3" drop spring.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#16 |
They do if you own a cut off wheel...
#17 |
#18 |
Buck, I just went through your Shiro thread and I'm part way through the farm truck build thread (I should be working lol).
Do you think I'll need an ECE or Porterbuilt trailing arm crossmember with my 8" drop and stock trailing arms.? I'm planning on keeping two piece driveshaft. Will one day shorten truck from LWB to SWB.
#19 | |
#20 | |
The PB trailing arm crossmember looks pretty sweet because of all the adjustments. Looks like I could center the wheels in the wheelwells and custom tune the pinion angle pretty easy. Really enjoyed your threads today and your TADD tagline seems pretty accurate.!! and of course I loved your '68 and the color.!! Love the slant noses.!!
#21 | |
![]() You are definitely doing one thing correctly, asking questions. There is an abundance of experience here on the board it will suit you well to take advantage of it. Make a plan and stick to it as best you can, but most of all have fun with your truck!
#22 | |
#23 |
Okay I have a few parts coming.
Porterbuilt has a 4-6 week wait for the control arms. I went with the 1" forward lower control arms and standard uppers as this was what they recommended for a 5" static drop. If I went for forward arms for both it would be too much for a static drop. I also went for their front shock relocate which is supposed to provide a better shock angle. I really struggled with buying Porterbuilt or the CPP tubular arms, mainly because I did not want to wait. But I like the fact that they are making good quality stuff in america and figured I'd like to support that.
#24 |
I also grabbed a bunch of the rear stuff I wanted from No Limit. They had it all in stock which made me very happy.
NO LIMIT Rear panhard Rear shock mounts Top mount sway bar
#25 |
And I grabbed these progressive bump stops and C-notch kit from CPP off of their ebay store. They arrived right away.
I saw the progressive bump stops on no limit's JT truck and thought they looked cool. If they don't work it's only $15.
