Old 03-02-2015, 11:39 AM   #1
thermoman
fan and shroud question
I am currently getting ready to put my 67 c 20 suburban on the road. I am missing the fan and shroud. I will probably put AC on it next year. My questions are.
Does the clutch fan diameter differ from non AC to AC trucks?
What makes the ac shroud differ from no ac shroud?
Any help is appreciated.
Charles
thermoman is offline   Reply With Quote
Old 03-02-2015, 01:14 PM   #2
sKnNyPpY
sKnNyPpY's Avatar
Re: fan and shroud question
The difference in the shroud is the depth, ac radiators are typically thicker so the shroud is shorter. This was the best deal I found on a heavy plastic shroud.http://www.usa1industries.com/1967-7...-2wd-w-ac.html I had to trim mine because I have a long water pump. Advance Auto had the best deal on clutch and blades, the most important making sure you have the right depth clutch (not too close to radiator) and fan size for the shroud.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 03-02-2015, 03:31 PM   #3
thermoman
Thank you
Old 03-03-2015, 03:59 PM   #4
Kaptain Kadian
Kaptain Kadian's Avatar
I have a ac fan and clutch I pulled off of my truck a couple of months back if you are interested in it
Kaptain Kadian is offline   Reply With Quote
