03-02-2015, 09:25 PM | #1 |
C notching the frame?
I've searched the forum looking for how low you can go without C-notching the frame and only came up with newer vehicles. There are some great reenforcement threads on how to beef it up. So looks as if you can 4 or so inches and still have 4 or 5 inches of travel. What have you guys done?
Jeff |
03-02-2015, 09:37 PM | #2 |
Re: C notching the frame?
IMO, the most you can take out of the frame without changing the top rail is 3 inches. That's what I did and boxed about 6" on either side of notch. Have about 3 1/2 inches of travel and you can see how mine sits. I did raise the bed 2 inches and could have modified the top frame rail to take advantage of that but didn't. I think BAM did. You might look at his build sheet.
03-02-2015, 09:41 PM | #3 |
How much did you lower it tho? I'm looking to lower mine 4" and want to if most or none are C notching at that distance. Sorry if my question was unclear. Mine is a 53'.
03-03-2015, 12:49 AM | #4 |
Mine sits rather high because it has 255-60 15 tires but you can see where the center of the axle sits and I have between 2-1/2 and maybe 3 inches of clearance between the axle and the frame.
This is a stock 48 sitting at stock height for comparison. I'd say my truck is probably lowered 4 inches in back but without a notch the axle hits the frame way too often.
03-03-2015, 10:34 AM | #5 |
Mine
03-03-2015, 08:00 PM | #6 |
Thanks guys!
