Old 03-05-2015, 04:01 AM   #1
Giantsniners72
COLUMN SHIFT LEVER question.
Mine is all rusted out on my 72 and i would like to replace it. Iv been doing some research and seen and read that i shouldn't try it myself (Not exactly a pro but i know my way around a tool box). There is a spring behind the lever and if im not careful it will drop? My question is what would be the proper tools and steps to put a new one on. Thanks for any feed back!
Giantsniners72 is offline   Reply With Quote
Old 03-05-2015, 08:48 AM   #2
jaros44sr
jaros44sr's Avatar
Re: COLUMN SHIFT LEVER question.
I would use a drift pin punch, and knock the pin down (but not all the way out) just enough to slide the shift lever out.
I ve never done it it, but it seems like a simple fix. Don t use a tapered punch
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
