![]() Join Date: Feb 2010
Suggestions on tire size with porterbuilt
Hello all, I'm running full porterbuilt extreme front and back. It's time to get tires for the truck. I'm running the gm transits, as far as I know they are 22x9 with 6 back spacing. Any suggestions on tire size. I am not good at all sizing tires and could use some help here to keep me from ordering multiple tires. Thanks for the help in advance guys
#2 | |
Sofa King Crazy!!
Re: Suggestions on tire size with porterbuilt
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
The dropmember is designed to lay frame up to a 28 inch tall tire.If your running any spacer or adapters for those wheels that can change things.
I heard back from porterbuilt on this and they suggested 265/35/22
I have the extreme front and rear drop members as well and I'm running a 285/30/24 out back which is around 30.7" tall and a 265/35/22 up front which is right about 29.3" tall. I have issues with my front tires hitting my hood but my truck is body dropped as well.
so 22x9 is doable? I'm running extreme front n back with PB narrowed arms. Im ready to order my wheels just want to be sure before i ordered that I wont run into any problems up front. Thanks.
Diggin The SquareLife
yes
