big block fan shroud
Can somebody show me a pic of a big block fan shroud. I have th 21 inch radiator with the mount on top of the core support. I cant find a fan shroud to fit. thanks JOE
Re: big block fan shroud
I can take a picture tomorrow, its been raining non stop here. I used a fan shroud from a 77 with a 454. Required a little bit of trimming to get it to fit.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
I have a factory 454 in my 77. I can snap a photo or two tomorrow after work.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
thanks guys. any help would be great.
What year is your big block?
x2.
What year truck? Fan shrouds changed w/the year model & core support changes.
I have a 78 suburban. mine has a small block 400 in it. I used the 21 inch tall radiator out of a big block truck and got the mount with 5 bolts across the top of the support. the rad is 28 inches wide.
Here you go, BBC rad and shroud combo in a 80 c10 w/ SBC.
Here is my factory BBC Radiator shots. Hope this help you. Please excuse the dirty engine bay LOL
thanks guys that's great. one last question is can you measure the distance between the mounting holes of the shroud. the only reason I ask is so I can make sure my aftermarket mount is the same as the original.
