Old 03-10-2015, 03:39 PM   #1
slammed57
slammed57's Avatar
door weather seal
Who makes the best (thin) weather seal that doesn't alter pannels alignment when installed for a 57 truck door
slammed57 is offline   Reply With Quote
Old 03-10-2015, 07:00 PM   #2
DransportGarage
DransportGarage's Avatar
Re: door weather seal
They'll all alter your panel alignment, but the softest and best that I've found is SoffSeal.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 03-10-2015, 07:06 PM   #3
slammed57
slammed57's Avatar
Thanks bob, do you think it's wise or even if possible to trim the seals so it won't alter the pannels alignment?
Old 03-10-2015, 07:09 PM   #4
DransportGarage
No, the seals have a smooth surface but the internals are a porous foam. They really can't be trimmed, other than on the ends. I have noticed a deflection around the windows when the seals are put in place.
Bob
Old 03-10-2015, 07:15 PM   #5
slammed57
slammed57's Avatar
great, Much Appreciated
Old 03-10-2015, 10:09 PM   #6
Stepside Jim
I also used Soffseal. Reading the many times people had issues when using new seals I was concerned.
I found the first time closing the doors they were tight, but the seals conformed quite well and everything fits good and the doors close nicely now.
Jim
Oh, on the bottom of the drivers side I had one plastic peg that out of place, I put a hole in the right place on the seal and reinserted the plastic peg, all is well now.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 03-11-2015, 07:42 AM   #7
slammed57
slammed57's Avatar
thank you jim so much soff seal it is then. thanks again
