03-12-2015, 01:58 PM | #1 |
1963 c10 heater questions
Hey guys got the truck home yesterday and looked at the heater core which was by passed and on the floor...I went to order a new one and found that maybe some stuff was missing? Is there a box that the core goes into? Here's a couple pics....thanx
03-12-2015, 02:00 PM | #2 |
Re: 1963 c10 heater questions
Heater
03-12-2015, 02:11 PM | #3 |
Looks like I'm missing the box that holds the core itself?
03-12-2015, 03:15 PM | #4 |
The heater core goes under the hood on the firewall, passenger side. There should be a larger box it goes inside of. Search on this forum for pictures. You didn't say what type of heater: Thrift Air, Deluxe, etc. as there are differences. Hope this helps.
03-12-2015, 03:29 PM | #5 |
this one has the fan motor inside so its a recirculation heater...sure looks like the core mounts inside as there are 2 holes to allow the hoses to attach to the core..
03-12-2015, 03:38 PM | #6 |
This is what is supposed to look like.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-12-2015, 04:02 PM | #7 |
here ya go. You can see where the heater core goes just by the position of the hose's in the box.
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
03-12-2015, 03:57 PM | #8 |
my 64 is all box mounted under the hood. Ill go grab a pic for you.
03-12-2015, 04:30 PM | #9 |
Check The Champ, Demonstrator
Your missing the plenum on you heater that retains the heater core. CdM picture above is incorrect for your application, he is showing a deluxe heater as you have the recirculating type like Slow Build picture.
Only one pictures in the shop manual for recirculating type heater in section 13 of the American version following the Air Conditioning section. The heater cores differ as well. Yours does not have the flow control valve as the engine compartment firewall mounted model.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-12-2015, 05:02 PM | #10 |
I'm with "Slow Build" on this one. Looks like your heater core is housed inside the cab on the passenger side. Same set up in my '60.
03-12-2015, 06:23 PM | #11 |
Looks like you guys are on the money again!! I'm missing the cradle or plenum .. I'll check the local used place for one...thank you
03-12-2015, 06:19 PM | #12 |
Enjoy your truck
I had mine apart last summer. There is a "cradle" with two straps that holds the core within the heater housing. It is slightly larger than the core, is open on all sides to allow airflow through it, and mounts to the firewall side of the housing (which allows the core pipes to stick through the firewall.
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
03-13-2015, 12:09 PM | #13 |
Didn't know about the core mounting inside. Learn something everyday!
03-15-2015, 08:56 AM | #14 |
Hey guys does anyone know a part number for a heater core that goes on this recirc heater? ...thanks
03-29-2015, 12:21 PM | #15 |
I am also looking for the same core
03-29-2015, 12:36 PM | #16 |
DIESEL 64 I found it Amazon.com: Spectra Premium 94477 Heater Core:...also here http://www.oreillyauto.com/site/c/de...2709&ppt=C0331
also here is what the parts look like that you are missing http://www.ebay.com/itm/1960-61-62-6...15f28b&vxp=mtr Last edited by jtrichard; 03-29-2015 at 12:43 PM. |
03-29-2015, 02:22 PM | #17 |
Hey thanx man I ordered one from LMC
05-27-2015, 09:46 PM | #18 |
I just bought a recirculating heater core from LMC and its no where near the same, the parts where the straps are supposed to go around are much too small. Did yours fit properly?
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
03-29-2015, 02:26 PM | #19 |
Here are some shots I took of my heater unit before refurbishing it. Different angles on how the core fits into the unit. Hope they help -- Cheers!
03-29-2015, 03:48 PM | #20 |
That helps a lot thank you ...I was able to obtain the box locally with the retaining straps..and man that's a great deal on that core!!
03-31-2015, 11:02 AM | #21 |
Just though I'd report back with how the heater core fits for the recirculating type heater ...I've shown the straps and the box...thanks for all your help...and also here's a pic of my ride today..
03-31-2015, 11:03 AM | #22 |
Straps
03-31-2015, 11:04 AM | #23 |
