Old 03-13-2015, 10:48 AM   #1
66LSx
66LSx's Avatar
Question LED Turn and Tail
Anyone running em ? Thoughts ? Curious if the front LED have both running and signal lighting (much like the rear). I know I'll have to swap out to an LED friendly flasher relay also . Pictures illuminated would be muey bueno
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 03-13-2015, 01:58 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LED Turn and Tail
I've got the rears with the socket built in them. They work fine in conjuction with regular bulbs up front. As long as the lights (LED or bulb) can put enough load on the system, they'll blink. Most of the new setups have the socket and resistor included, but if your retrofitting them yourself, you'll need to add resistors.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-13-2015, 02:22 PM   #3
66LSx
66LSx's Avatar
Was planning on hard wiring and making my own quick removeable pigtails and was going to shrink tube in a 10k resistor ( I think what I used ) when I did LED tails on my old motorcycles. I want to get away from relying on the unreliable 1157 socket itself
1966 C10 SWB Fleet
Old 03-13-2015, 02:24 PM   #4
66LSx
66LSx's Avatar
I really want to make sure that the fronts can serve as "running lights and signal" along with what the LED looks like when just the running lights are on
1966 C10 SWB Fleet
Old 03-13-2015, 06:51 PM   #5
Cooper197
Cooper197's Avatar
Yes!
I have LED lights up front and in the back. They function as running lights (dimmer setting) and then turn signals which are brighter. However, it is really easy to put the plug in the wrong direction and make it so that it's the opposite.
I ended up hardwiring in my lights to bypass the socket that I was having issues with, but I also went ahead and changed out the flasher with one made for LED's. It's also a little bit louder when it ticks which is kind of nice!
Running Lights up front
Out back
Cooper197 is offline   Reply With Quote
Old 03-13-2015, 07:33 PM   #6
AcampoDave
AcampoDave's Avatar
Cooper, is installing the l.e.d flasher simply a matter of unplugging the stock flasher and plugging in the new? Can one be bought at the parts store.?
AcampoDave is offline   Reply With Quote
Old 03-13-2015, 07:38 PM   #7
Cooper197
Cooper197's Avatar
Basically.
I got mine from Napa for less than 10 bucks. There were two very minor changes from the original one.
1) The LED one required a ground
2)The pins were switched. So maybe they gave me the wrong one, but I just made two little jumper wires and put the two pins in the right place that way and it all works great!
Old 03-13-2015, 08:35 PM   #8
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I my opinion, you may have missed a very cool option...
Now that you have the LED flashers into place, you are all rigged for what I have done, which is a very modern approach.
I have fitted my truck with the clear bezels in the front, but I am running what they call a "switchback" LED lamp.
When the parking lamps are on, they illuminate white. when the turn signal is activated the white drops out & illuminates an amber blink. as soon as the turn signal is canceled, they return to white light for the parking lights, all while the opposite side never misses a beat, and reamains white the entire time, very cool, I think anyways.
My entire truck is fitted with either LED or HID on the exterior.
Check out ddmtuning.com they specialize in automotive lighting, it may cost a few bucks more, but they are LED's they shouldn't ever burn out...
Modges'66 is offline   Reply With Quote
Old 11-26-2015, 01:00 AM   #9
WOLFMANmike
WOLFMANmike's Avatar
hey i was wondering what hid kit did you buy for the truck from this site ?
WOLFMANmike is offline   Reply With Quote
Old 11-26-2015, 01:32 AM   #10
Pizzaholic
Instead of wiring for a whole new setup, I just used some "For Off-road Use Only" LED bulbs that I found at Autozone that fit in the stock taillight sockets. I put them in at the same time that I added the third brake light.
Pizzaholic is offline   Reply With Quote
Old 03-13-2015, 08:40 PM   #11
66LSx
66LSx's Avatar
Sorry guys... doesn't matter anymore... truck got totaled tonight when I was driving it home from work....{2nd drive of the season} (other driver at fault) ... another thread... with pictures to come.... unfortunately.
1966 C10 SWB Fleet
Old 03-13-2015, 11:14 PM   #12
Dubnova
AW NAW! Dude, I am sorry about that. I hope you make out ok and didn't get hurt.
Dubnova is offline   Reply With Quote
Old 03-14-2015, 01:27 AM   #13
cv65
cv65's Avatar
Sorry to hear about your truck ,Lm sure everybody here feels for ya,Im an oldman and seen my share of bummers,just get another one and with what you know now its always a little easyer build.
cv65 is offline   Reply With Quote
Old 03-14-2015, 01:27 AM   #14
Captainfab
60-66 Nut
OH man! that really sucks. I hope you are all right? Don't ignore any seemingly minor pains, get checked out if you haven't already.
Old 03-13-2015, 08:52 PM   #15
Modges'66
Modges'66's Avatar
Whoa!
That totally SUCKS!
Old 03-13-2015, 09:41 PM   #16
cv65
cv65's Avatar
my leds
I have parking lights , Turn signal and brake lights are brighter ,I have turn signals in front with headlights on but no "running lights" light switch has parking lights half pull, headlights full pull, started with rear lights led and front lights regular,worked fine with stock flasher ,added front leds and would not blink,changed flasher to led type with ground and mine came with a adapter that changed polarity ? and it worked!
Old 03-13-2015, 10:04 PM   #17
cv65
cv65's Avatar
flasher bought on ebay
http://www.uapac.com/antique/led-fla...apter-12v.html
Old 03-14-2015, 09:35 AM   #18
Clyde65
Clyde65's Avatar
man, that sux! I am so sorry for this loss. I hope and pray you and everyone else is safe and healthy. Was this your SWB or the LS truck?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-14-2015, 01:55 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Damn man that sucks.
Old 03-14-2015, 04:19 PM   #20
63burban
Chevy addict
Sorry to hear about your truck, always sucks when an old vehicle gets hit.
BTW, I sell United Pacific LEDS and Flashers, very nice products.
63burban is offline   Reply With Quote
Old 03-14-2015, 05:22 PM   #21
66LSx
66LSx's Avatar
Everyone safe... Truck not so much
1966 C10 SWB Fleet
Old 03-14-2015, 10:55 PM   #22
Jeff La
That sucks is right. Hope everything goes well for you.
Jeff La is offline   Reply With Quote
Old 11-25-2015, 05:19 PM   #23
JeffWoods
my fronts work fine, but the backs don't work right. any ideas?
JeffWoods is offline   Reply With Quote
Old 11-25-2015, 05:51 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not lighting up, or not blinking? As some have mentioned, LED's don't put the same impedance on the circuit, so they won't trigger the blinker without adding a bulb or resistor (the pre-socketed lights sometimes do have a resistor added, but each is different).
Old 11-25-2015, 07:44 PM   #25
Cooper197
Cooper197's Avatar
Check the ground.
Had issues with my rear lights working until I cut the ground wire off the plug and grounded it.
Ultimately ended up just doing away with the plug completely and directly wiring all my lights in.
