Softening the ride on a 72 3/4t 4x4
My truck rides like a 3/4 ton 4x4. I don't mind it, but the wife refuses to ride in the truck until I soften up the ride. Would removing a few of the heavier shorter leaf springs help?
I'm certain the shock absorbers all need to be replaced. But when shocks fail, don't they usually get sloppy, not stiffer?
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
Re: Softening the ride on a 72 3/4t 4x4
Do you have lift springs?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
The truck is lifted, but with blocks, not extra springs.
Moderator
![]() Join Date: May 2007
I am fairly certain you will not be able to soften it enough for her liking. Been there done that
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#5 | |
I do suspect the bench seat currently in the truck might be partly to blame. It's REALLY springy. I've got the original bench seat in the backyard, eventually plan on new foam and upholstery on it, that should help.
What size wheels and tires? What pressure are you running in the tires?
Do you have blocks on the front springs too?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
My x-wife wanted more than could be expected,too. More like expected the impossible. The truck I still have and I think it rides fine (not that she ever complained about that).
If your truck is lifted it will ride better stock. I seriously doubt you have blocks in front and if you do, park it till you get rid of them. that's a bad set-up and ride is the least of your worries.
Carpe manana
![]() ![]() Join Date: Dec 2010
Are you running rubber or poly mounts for the cab? If old OEM or poly you may find that swapping for some fresh rubber mounts may help some.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
