Old 03-15-2015, 10:24 PM   #1
jb3t
Under Hood Insulation Replacement - Options
Hi... I've got a '78 C10 and the original under hood insulation is falling apart. Looking to replace. See some on LMC and Classic Car Parts but am curious as to what others have done.
http://www.classicparts.com/1973-98-.../#.VQY8Shj3arV
jb3t is offline   Reply With Quote
Old 03-15-2015, 11:01 PM   #2
SilverMiner
SilverMiner's Avatar
Re: Under Hood Insulation Replacement - Options
Subscribed - I'm looking to replace mine as well. Not sure how much difference it makes, but for originality reasons I'd like to fix what is there and not have it hanging down looking like crap.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 03-16-2015, 12:00 AM   #3
jb3t
Doing a lot of looking on the web and YouTube. Looks like most are cut to fit. Seen them as cheap as $30 and up over $100. Would like one that is fit and comes with clips. Not having luck finding one that's priced reasonable.
Old 03-16-2015, 06:39 AM   #4
tucsonjwt
I just replaced mine with the LMC version. It is not as thick as the OEM mat and is flimsy, in my opinion. It does not dampen sound as far as I can tell. I would look elsewhere. I think fiberglass is not the best material for this application. The rainwater from driving through puddles and possibly oil/AC compressor oil thrown up by the belts ruins fiberglass quickly. A denser material, maybe a urethane foam type mat would be better. Perhaps dynamat or similar floor mat.
tucsonjwt is offline   Reply With Quote
Old 03-16-2015, 11:30 AM   #5
Shifty One
Shifty One's Avatar
Thanks for the timing of this answer...I was just about to pull the trigger on a set...
Old 03-16-2015, 08:06 PM   #6
tucsonjwt
Save your money for pothole related suspension repairs.
Old 03-17-2015, 11:50 AM   #7
Shifty One
Shifty One's Avatar
That's why I bought 4WD, to handle what Tucson considers "streets".
Old 03-17-2015, 09:08 AM   #8
SCOTI
SCOTI's Avatar
I agree..... I purchased the same stuff from LMC. It's sitting against the wall in my shop. Not worth the time for the install.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-16-2015, 11:18 PM   #9
jb3t
Anyone use these?
Metro Moulded HI 1 Hood Insulation Pad https://www.amazon.com/dp/B0072HQZE4..._QW5bvb1KG53HD
http://www.classicpartsusa.com/produ...rts_Hood_Items
Old 03-17-2015, 08:25 AM   #10
tucsonjwt
Those all look the same as the LMC stuff. The material was broken through where it was folded up for shipment, which gives you an indication of how flimsy it is. 1" is "nominal" thickness, in my opinion - really only about 5/8" thick when installed, in my experience. The material is not very dense and is too fragile for my use- about the density of wall insulation or less.
Old 03-17-2015, 09:02 AM   #11
homemade87
I replaced mine when I did the resto . I was like others about the aftermarket stuff .I checked with the local dealership and ordered mine from there . It seems to have a pretty good face side on it . Not indestructible but durable . It comes trim to fit like all of them . I had an extra hood so I made a template out of cardboard for a pattern . Worked pretty good .Here's a couple pictures.
Also this comes on there truck and it is one big flat piece in a box .It is not folded so don't go pick it up in your car if you decide to get one . It is much larger than you need so you will have some left over . It does not come with anything like clips . You will have to pick them up . I believe it takes 24 of them . In my picture there is a place in the center for one that I was short . Have not got it put in yet .
Also , I believe it is about 5/8 thick .
homemade87 is offline   Reply With Quote
Old 03-17-2015, 09:32 AM   #12
JWall
Frequent Flyer
JWall's Avatar
I went with the AcoustiHood ABS Panel from Quiet Ride.
I had some old thick stuff under the hood that created more dust under the hood than it did anything else.
I like the look a LOT better & it seems to sound the same in the cab as before.
- Justin
1 Owner 1976 SWB
Old 03-17-2015, 11:52 AM   #13
Shifty One
Shifty One's Avatar
Attachment 1378790
Attachment 1378791
Attachment 1378792
Attachment 1378793
Now that's sharp....
Old 03-17-2015, 12:25 PM   #14
TKCR
TKCR's Avatar
Attachment 1378790
Attachment 1378791
Attachment 1378792
Attachment 1378793
Nicely Done!!! That looks real good
TKCR is online now   Reply With Quote
Old 03-17-2015, 11:42 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
[QUOTE=JWall;7093894]I went with the AcoustiHood ABS Panel from Quiet Ride.
Looks very nice
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-20-2015, 11:07 AM   #16
SCOTI
SCOTI's Avatar
Just ordered one. I like the clean look....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-31-2015, 10:18 AM   #17
SCOTI
SCOTI's Avatar
JWall,
Do you remember how long it took for your underhood panel to arrive? I ordered mine @ 10:00am on 3/20 & it hasn't arrived yet. The order confirmation doesn't give any shipping info either....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-31-2015, 11:02 AM   #18
JWall
Frequent Flyer
JWall's Avatar
Originally Posted by SCOTI View Post
JWall,
It took a little while but I don't think that long... maybe around a week to ship out.
I think they are produced after you order them.
You might want to give them a call.
- Justin
1 Owner 1976 SWB
Old 03-31-2015, 11:24 AM   #19
Liberty
Liberty's Avatar
My insulation is really starting to fall apart too, is there any problem with just removing it completely without replacing it?
Liberty is offline   Reply With Quote
Old 03-31-2015, 11:35 AM   #20
SCOTI
SCOTI's Avatar
Nope.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2015, 09:36 AM   #21
74CustomK20
74CustomK20's Avatar
That looks MUCH cleaner.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 03-17-2015, 11:04 AM   #22
SCOTI
SCOTI's Avatar
100% better.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2015, 09:14 PM   #23
jb3t
Wow... That looks very clean. Looks like they run about $169 vs about $60. May be worth it.
http://www.quietride.com/catalogpdfs...ood_covers.pdf
Old 03-17-2015, 10:58 PM   #24
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed. Like the quiteride piece.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-17-2015, 11:23 PM   #25
Titomars
Titomars's Avatar
I also like the Quietride kit too. It's a shame they don't offer the kit for the cowl induction hoods.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
