Old 03-17-2015, 09:01 PM   #1
dtkarst
What wheels are the C20 guys running?
Ive got later style 8 lug rims on my 65 C20 and they need painted and hubcaps possibly. What are you all running? Ive been thinking about painting them black but dont really have any hubcaps to use. they are the later 16" nub rims. Or what newer wheels will fit on it? Ive thought about switching them out to the early 2000s 8lug rim but not sure what thatd take. any help would be great.
dtkarst is offline   Reply With Quote
Old 03-17-2015, 10:03 PM   #2
buckroseau
Re: What wheels are the C20 guys running?
I bought some 22" rims with 305/45's on them off CL for $300 bucks. Not sure what your looking for, but these came off a 2006 duramax diesel.
Matt
buckroseau is offline   Reply With Quote
Old 03-18-2015, 11:17 AM   #3
earl84
Matt
If I would have just read the tire size, I would never think that I would like this, but that looks pretty dang nice! Do you have any rubbing issues?
I have later model steelies with the nubs, painted white with 225/70-16 black wall tires. Rear is bags on Schrader valves, front is 2 inch CPP lowering springs. Not the best pic, but you can see it OK.
earl84 is offline   Reply With Quote
Old 03-18-2015, 10:41 PM   #4
buckroseau
No rubbing issues to speak of. The rear was really close, maybe 3/16" from the inner box edge. There was a lot of material there so I cut it back about a 1/2" on each side on the rear. Now it's not even close.
Front on mine was torsion bars, I backed them off and dropped the front end a good couple inches. I set a couple jack stands under the rear of the frame and then heated the rear coils with the rosebud tip on the torch. Dropped the rear a good couple inches until they hit the jack stands.
Old 03-21-2015, 10:17 PM   #5
jdl71
jdl71's Avatar
I was thinking the same thing. I'm normally a fan of much more traditional wheel and tire sizes, but that does look sweet.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 03-22-2015, 02:46 PM   #6
Hammer Down
This is what it looked like before the new wheels and tires.
Hammer Down is offline   Reply With Quote
Old 03-22-2015, 06:41 PM   #7
jdl71
jdl71's Avatar
Where did you get 8 lug 15 inch wheels?
Psalm 23
64 C10
66 K20
Old 03-17-2015, 10:31 PM   #8
dtkarst
Did you have to get an adapter for them or anything to fit?
Old 03-17-2015, 10:36 PM   #9
buckroseau
No, bolted right up. Front end is stock. I did a rear axle swap using an axle out of a 97 C3500 SRW. The rear axle is only 5/8" wider wms to wms. That being said, they would have bolted up to the rear stock axle.
Old 03-18-2015, 03:55 PM   #10
blazer-k5
blazer-k5's Avatar
Like 1980s...3/4 1 ton wheels work also.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 03-20-2015, 12:22 PM   #11
dtkarst
Found some stock 16" rims from an 07 2500. Back spacing is 5" and bolt pattern is 8x6.5 will they work?
Old 03-21-2015, 09:34 PM   #12
Hammer Down
235/75/15
Old 03-21-2015, 10:14 PM   #13
jdl71
jdl71's Avatar
Originally Posted by Hammer Down View Post
Thats a 3/4 ton?
Psalm 23
64 C10
66 K20
Old 03-22-2015, 02:41 PM   #14
Hammer Down
Yes it's a 3/4 ton 8 lug
