03-18-2015, 06:46 AM | #1 |
New exhause Installed!
*Edit, that's what I get for Posting before my first cup of coffee... "New Exhaust Installed"
Quite a while back I ordered a manifold back dual exhaust system from Summit and a pair of Thrush Turbos. I finally got around to getting everything on the truck over the weekend. What a huge difference! I still have one or 2 places to tweak the fit on the passenger side... what a PITA. But it all fit with minimal cutting. At some point I will get around to welding everything, but I wanted to just clamp it up and put a few miles on it before I make everything permanent... Anyway out with the old and in with the new... It is factory location outlets, that probably has something to do with why it was so tricky to install... for anyone installing one of these kits, I suggest starting with the drivers side and then doing the passenger. The stock brackets on the DS made it a lot easier to get everything in the correct place, then its just a mirror image on the other side... at least for the hanger locations. I also had a set of mid length headers I was going to put on... not a chance. they hit frame and motor stands. I decided to stick with the ram horns, and actually ordered a new set, for when I do my cam and head swap in a few weeks. |
03-18-2015, 07:35 AM | #2 |
Re: New exhause Installed!
looking good Mr. handy! I bet it sounds a lot better. Nice work on the install.
CHEVY/GMC VIN DECODERS |
03-18-2015, 08:49 AM | #3 |
Florida Edition
Truck is coming along nicely Andy!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
