03-18-2015, 04:27 PM | #1 |
Fuel Sending Unit Fitting Question..
So I swapped the in cab tank for a new one and a new sending unit. I took out the old one, put in the new gear. No leaks, runs great and then I turn it off and the sending unit-fuel line connection is just weeping a bit. I decide to snug it up, 1/4 turn, and it snaps. Now the tank has gas in it and the brass snapped in half.
My question is, Would it be worth it to remove old brass fitting, off of the old tank and putting it on the new sending unit in the new tank? Problem is that the sending unit line is flared on the inside and soldered to the brass on the outside. Otherwise it is getting a new sending unit and that is $50... Thoughts?
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
03-18-2015, 07:00 PM | #2 |
Who Me?
Re: Fuel Sending Unit Fitting Question..
Will the brass fitting come off the chrome line? If it does, can you use a compression fitting on that line? It may take an extra fitting to complete that.
Look at the picture with the green check mark. http://www.thomson-caravans.co.uk/ad...ionfitting.htm
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
03-18-2015, 07:07 PM | #3 | |
#1 cut off brass fitting,use fuel hose and 2 clamps,probably not the safe fix! #2 bite the bullet and get the 50 dollar sender. sleep at night enjoy your truck and get ready for the next------ problem,you know its coming !! #3 or use compression coupling as suggested above I didnt think of that Last edited by cv65; 03-18-2015 at 07:14 PM. Reason: agree with new post |
03-18-2015, 07:30 PM | #4 |
03-18-2015, 07:55 PM | #5 | |
Who Me?
03-18-2015, 09:58 PM | #6 |
03-19-2015, 05:50 AM | #7 | |
Sam Last edited by luvbowties; 03-19-2015 at 05:57 AM. Reason: add info |
03-19-2015, 05:53 AM | #8 | |
Sam Last edited by luvbowties; 03-19-2015 at 06:01 AM. Reason: splg |
03-19-2015, 09:44 AM | #9 | |||
I have been looking, nothing yet. Nothing has the strength of NOS. Quote:
03-19-2015, 09:43 AM | #10 |
Chevy addict
Compression fitting
