1969 C-10 CST Build
This is my 1st new thread. I just picked up a 1969 C-10 CST long bed that i will convert to a short bed, lowered nice ride.
Re: 1969 C-10 CST Build
Any comments or suggestions are welcomed
![]() Join Date: Jan 2015
Sweet! Keeping it the same color?
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
My plan is flat black with red rims and baby moons with white walls, or red with black rims and white walls. 2'' drop on the front, 4'' drop in the back, nice rebuilt 350, hickory wood bed. I have built a few cars, but this is the first from ground up. Thanks to allot of you here, I am almost to just a frame. More pics to come
So, here are some updated photos
ready to remove motor, want to see if it is 4 bolt main or not.
a few more pics
Great start to the project! I wasn't so lucky when I pulled the oil pan off. It was a fifty-fifty chance with the numbers I pulled from the block, but was certain it would be a 2-bolt seeing it was built for the LA area.
Welcome to the board from another washington stater. Nice start to a project!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Mar 2014
Love the 69.. wasnt this up for sale just today or yesterday on CL? I thought I saw a post on here about it. Anyways, great plans. Hoping to get mine in flat black paint over this primer I have now and pretty much same idea as you.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
Thanks to you alI. I appreciate your time to comment.
Swamp Rat, good to know another Washington state person. As for the truck, it was on craidslist n Yakima wash. For 1000. But I got it for 800.00 and drove it home where it is now in pieces. |
Update : got allot of parts in, allot. Repair panels, fuel tank, radiator, and so on. One thing I ordered and now I'm concerned with is I bought an HEI distributor, mini starter and tilt steering column from KMJ. A few days ago I came upon an article here about the tilt and the poor construction, and now I'm concerned. Oh well, live and learn I guess.
You going w/ 350 crank? or make it a 383???
Even though most here froth at the mouth for a factory roller cam block or LS, you've got a rock solid foundation block for an awesome build!!! Awesome find! Another classic saved!!! |
#15 |
Ya, i would love to build a roller motor, but i have decided to go with just a good ole 40 over 350, 268h flat tappet cam, roller tip 1.6 rockers, hyper pistons and such, with Vortec heads i was given and high rise carbed intake with a good ole 625 carter carb.
#16 |
So it has been some time since i have posted anything on here about the truck. So, here are some new pics along with an update where i am to date.
Cab is completely sand blasted by me, all the rust panels fixed on the cab, dash removed and repainted with Eastwoods Rat Rod Satin Black. Then I sprayed the underside of the cab with bed liner. Now I have cut the frame down from a long box to a short box. Here is where i am and here is what i need your all help with. I am adding 2.5 drop spindles and 1" drop springs in the front with disc brake conversion, then in the rear i have 4" drop springs. but here is where the questions are. Do i need to install an adjustable arm and do i need to add shock mount relocates? any and all comments welcome. |
#17 |
more pics, the frame getting cut
#18 |
more
#19 |
You will need to relocate your rear shocks but your front shocks will be fine.
I would buy a deluxe bent trac bar from CPP because the longer the trac bar the less the rear axle moves from side to side when the suspension travels and also you can put a cool looking finned aluminum rear differential cover on. |
#20 |
![]() Join Date: Nov 2010
Watchin
#21 |
making short work of it! no pun intended
#22 |
UPDATE: So i have been sand blasting and sand blasting and more sand blasting. Did you know that sand dust and your neighbors pool do not get along!!! I was asked to move my blasting area, so i moved to the side of the shop to be nice and it actually is better. All the suspension parts are apart and sand blasted. I tore the rearend apart and installed new pinion seal and axle seals. I also know now that i have 308 gears, not posi which is fine with me. The frame is yet to be blasted yet, but i will paint my parts first, then blast the frame. pics to come. finally seeing progress
#23 |
Your doing some excellent work. The cab floor looks great with the bedliner.
Scott |
#24 |
SDuckworth13 - Thanks. Watch as others have used bed liner on the bottom of the cab and figured that is a good idea, so I did. I will also use it on the inside of the wheel wells.
#25 |
Update: so i got a lot of of the sand blasting now primed and some of it painted with Rustoleum semi-gloss black, with a HF paint gun. Process is long and i am kinda anal about doing it right the first time, but its getting exciting to see the hard work start to come together.
