Always on the hunt...
![]() Join Date: Sep 2006
1971-72 NP205 t/c shift levers for Mr Banshee
Mike, you have first call on these levers since you asked about them. These are all 71-72 style t/c shifters, two of the levers are the painted type one of which has been drilled and had a grease zerk installed and comes with a pivot bolt, the other one pictured is an original chrome plated (p/n 3991932) lever pulled from a 72 CST blazer. Cost would be $50. on either of the painted levers or $85. for the chrome CST/Cheyenne/Sierra lever. Let me know, Mel.
![]() You had also asked about a greasable pivot bolt, so if you dont go with the above drilled shifter with the grease zerk then you could go with one of these GM (now discontinued) greasable 9/16 NC shift lever pivot/shoulder bolt, bushing and zerk NOS setups that I have available in this old thread link: http://67-72chevytrucks.com/vboard/s...d.php?t=251225 Last edited by Classic Bowties; 03-20-2015 at 03:44 AM. Reason: added thread link |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 1971-72 NP205 t/c shift levers for Mr Banshee
I'll jump in line for a set of the bolt/zerk/bushing behind Mr Banshee...thanks.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: May 2003
I could use a bolt/zirk/bushing also if you have another one ?
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
![]() Join Date: Jan 2007
hi, i am also interested in the bolt/zirk/bushing set up!
Carpe manana
Bump
![]() Join Date: Jan 2015
If mike doesn't take the Crome cst/chyenne t/c lever I'll take it and I also would take a bolt/zerk/bushing set up if available
![]() Join Date: Jan 2013
Classic Bowties, I will take the Chrome Shifter and the NOS zerk fitting style pivot bolts. PM the payment details. Thanks Mike
#8 | |
Payment sent, Thanks again Mike.
#11 | |
![]() Join Date: Nov 2014
I'll take 2 bolt kits if available
