Old 03-22-2015, 10:34 AM   #1
Macster
1979 GMC S/B LS Swap-Carb intake
Macster is offline   Reply With Quote
Old 03-22-2015, 12:42 PM   #2
mattcrp1
mattcrp1's Avatar
Re: 1979 GMC S/B LS Swap-Carb intake
Nice looking project. Do you have any more info?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-22-2015, 03:59 PM   #3
Macster
Sure
I had a ZZ 502 in her; nice for a daily driver when gas isn't 3.80 a gallon. I have done a few vortec swaps in 67-72 Chevy';s and decided to get a bit more economical.
2003 5,3 Vortec
Stock Ex. manifolds-I had header problems
Edel 7118 intake and performer 600 cfm
Stock fuel tank;electric pump/regulator
700R4-Monster Tranny
3.73 rear end
Just about it; nothing overly fancy and I have yet to see a carbureted LS in this area.
Old 03-22-2015, 04:11 PM   #4
Macster
Oh, if you are doing an EFI swap; been there on 67-72's. if I can help. just ask...
Old 03-23-2015, 04:11 PM   #5
LSX408
Very nice, good looking truck!
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 03-23-2015, 07:54 PM   #6
l92powered77
Exclamation Re: 1979 GMC S/B LS Swap-Carb intake
Ok first of all nice 79.really digging that color combo.that swap looks pretty damn clean. Keep up the ls swapping! Keep us updated, my next swap is a 67-72 or 77-81 camaro/trans am.might have to ask for help on c10.
l92powered77 is offline   Reply With Quote
Old 03-24-2015, 04:03 PM   #7
mattcrp1
mattcrp1's Avatar
Very cool, my 76 is almost "road worthy". How is the drivability with the carb set up over the efi set up? I have never driven a carbed ls so I have no point of reference.
IG mattcrp1
Old 03-24-2015, 04:21 PM   #8
Justin@EntropyRad
Justin@EntropyRad's Avatar
Clean swap, was curious myself as to why the carb was used
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 03-26-2015, 09:16 AM   #9
mattcrp1
mattcrp1's Avatar
What size tires are you running?
IG mattcrp1
Old 05-15-2015, 08:59 AM   #10
Macster
Okay, First of all sorry for the delays; truck has been pitching a Fit.
The Carb LS swap is done; Edelbrock controller is not doing its job very well so back top the Truck Intake.
Old 05-15-2015, 09:01 AM   #11
Macster
Tires on the GMC 1979 were 255/70 15. Found the Rallys on a truck in the salvage yard. 15X8 and the center caps;I think 6 rims and caps for 100 bucks. seemed fair to me.
Old 05-15-2015, 09:05 AM   #12
Macster
Also, Carb intake was what I was referencing not running well; fowling plugs. like I said, back to the stock Vortec truck intake:
Fuel system will be a 1987 Fuel Tank and pump set up; pump puts out 135 PSI and the tank is baffled; 200.oo set up from Rock Auto.
Fuel out-efi Hose to 10 or 40 Micron inline. 3/8" Not to hose barb input; Braid 6 AN to the inlet on the intake. return line I think is 5/16 and low pre4ssure so I will probably run 5/16 EFI hose to the pump return; not sure if I have enough room for tube to AN crush fittings. I will try and post my results.
Old 05-15-2015, 02:47 PM   #13
LSX408
Nice clean swap!
2014 Chevy Z71
