03-24-2015, 04:18 PM | #1 |
door jam wire looms
Has anyone installed a set of braided steel wire looms on there truck? If so, what is the best brand and what length do I need?
03-25-2015, 10:42 PM | #2 |
Re: door jam wire looms
Are you sold on the steel braided? Is rubber not an option?
03-25-2015, 11:53 PM | #3 |
meowMEOWmeowMEOW
Don't know anything about the metal ones, but I've used the rubber parts-store ones on other projects and they worked fine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-26-2015, 01:19 PM | #4 |
I never even thought about using the rubber ones. The ones that I have seen look like I would have to drill a larger hole. Do you have any examples of the ones you are using?
03-26-2015, 01:40 PM | #5 |
03-26-2015, 01:41 PM | #6 |
Sorry about the big photos, I don't know why they come out like that.
03-26-2015, 04:23 PM | #7 |
03-26-2015, 04:41 PM | #8 | |
03-26-2015, 10:03 PM | #9 |
i really like that. was it difficult to install?
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
03-28-2015, 02:05 PM | #10 |
Not at all. You may need to power them up to adjust the regulator. With the screws they provide with the cranks it seems they're supposed to be attached from inside the door going out to the crank. If you need to remove the crank for any reason you would have to completely remove the regulator/motor assembly. I just picked up some longer screws and used some quick nuts. The switches are threaded, pulling to the door when attached with screws from inside going out but attaching from the outside in required the quick nuts. I had to remove the lip on the crank hole with a dremel to attach the clips. Compared to what you've been doing this should be a breeze.
03-26-2015, 02:36 PM | #11 |
meowMEOWmeowMEOW
The ones I've used from the parts store looked pretty much like those ^^
03-27-2015, 07:44 PM | #12 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Just for reference, here is a pic of my braided wire loom guards.
They work awesome, and look great. I am not sure on the brand but I can try to remember to look for the package the next time that I go to work on my truck. I know that I still have the package, as there were some extra parts for multiple apps. The rubber ones that you have look like they will work great also...They look like an OEM style part.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
03-28-2015, 02:28 PM | #13 | |
03-28-2015, 03:02 PM | #14 | |
04-03-2015, 04:49 PM | #15 | |
05-26-2015, 04:31 PM | #16 |
Where are you all running your wires after they enter the door jamb. I can not see any openings on that part of the jamb.
