Old 03-24-2015, 07:23 PM   #1
Hawkerdriver
Hawkerdriver's Avatar
Accessory Drive
Hey guys I was going to buy a Holley Acces drive kit for my 5.3 swap in my 52 GMC will it clear the inner fenders has anyone used that kit? If not what about the stock LM7 truck drive unit. Thought I had it worked out but saw some pics now I am doubting??
Hawkerdriver is offline   Reply With Quote
Old 03-24-2015, 08:06 PM   #2
Iceburgh
Iceburgh's Avatar
Re: Accessory Drive
I cant speak for the Holley but I tried every stock unit ( including the LM7) and nothing will fit between the frame ( with Mustang II) and/or inside the inner fenders with out cutting them.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 03-24-2015, 08:10 PM   #3
Iceburgh
Iceburgh's Avatar
Re: Accessory Drive
Here is what I used.... it was in the price range I was willing to pay and had everything I need.
There are many others out there.
http://www.visualimpactperformancesystems.com/
1953 suburban build
Old 03-24-2015, 08:53 PM   #4
Hawkerdriver
Re: Accessory Drive
and with those did you have to cut anything?
Old 03-25-2015, 08:47 AM   #5
Iceburgh
Iceburgh's Avatar
Re: Accessory Drive
Not at all....fits in tight and neat
1953 suburban build
Old 03-24-2015, 09:30 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Accessory Drive
They will not you have to cut both sides
Old 03-24-2015, 09:30 PM   #7
Root2812
Root2812's Avatar
Re: Accessory Drive
Although I haven't gotten it yet I am going to use the Holley accessory drive bracket for the power steering pump and alternator. I am also going to ditch the AC and use corvette crank pulley and waterpump. I am going with the corvette spacing to gain clearance for an electric fan because the truck and f body dive set ups don't have enough space for me.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 03-24-2015, 09:40 PM   #8
Hawkerdriver
Re: Accessory Drive
DW thanks for the pics do you have a build thread? I was looking ahead and your steering shaft is about what I figured I would need to fab too.. what exhaust manifold are you running there?
Old 03-25-2015, 12:27 PM   #9
_Ogre
_Ogre's Avatar
Re: Accessory Drive
for the price they want for front drives, it's well worth fabricating your own
truk is also anti billet so price and all that shiny stuff turned me away from the kits
my motor came with a standard rotation water pump which steered me to v belts
though serpentine would have been as easy to fabricate for a fraction of the cost
i also didn't like how high the kits mount components
only the alternator is above the water pump, the ac and ps pump are down low in stealth mode
shop air compressor timer
Old 03-25-2015, 02:11 PM   #10
OrrieG
OrrieG's Avatar
Re: Accessory Drive
I made all of my mounts out of flat stock and painted. My personal opinion is that the aftermarket stuff takes the attention away from the engine itself and puts the focus on the accessories. I also think they look way to clunky and overbearing. The TF have more width between the inner fenders so the AC and alternator can be laid off to the side. I would estimate $20 in metal and paint and about 8 hours of fabrication time for the PS, AC and Alt brackets. Ramshorn manifolds helped too.
