Old 03-25-2015, 01:14 PM   #1
FlameOut
Routing power steering hoses
Would anyone have any photos of the correct way the power steering lines should be routed on a 72 with a 350?
I swapped from a 250 to this 350 and these lines just don't seem right. Of course, the way that power steering bracket was designed, certainly doesn't make it easy to get to. I have them routed through the bracket. This is a K10, but I don't think that would matter? I checked on Rockauto for power steering lines, and they list the exact same ones for the 6 cyl and the 8 cyl engines
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 03-25-2015, 01:40 PM   #2
Fitz
Re: Routing power steering hoses
Yeah, Rockauto is the definitive expert on parts for our trucks.
Just make new ones that fit. Any local AC or hydraulic shop can shorten and re-crimp your old hose for you if you don't want to spring for the PTFE/stainless high pressure hose and fittings I used.
Fitz is offline   Reply With Quote
Old 03-25-2015, 02:25 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
Here is how mine is routed, its a big block so I hope this helps for reference anyway.
Number98 is offline   Reply With Quote
Old 03-25-2015, 02:41 PM   #4
Lou Boffa
Lou Boffa's Avatar
subbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 03-25-2015, 03:13 PM   #5
FirstOwner69
FirstOwner69's Avatar
These are exactly like the originals on my 69 with 350. In fact, the steel part of the return line IS the original. First pic is routing from pump under inner fender.
FirstOwner69 is offline   Reply With Quote
Old 03-25-2015, 03:25 PM   #6
ChevEE
ChevEE's Avatar
Subscribed
1970 C-10 lwb, 307 V8, THM-400
1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver)
ChevEE is offline   Reply With Quote
Old 03-25-2015, 03:31 PM   #7
FlameOut
Thanks for the photos. I think I may need to do a little fanegaling to get mine fitting properly. I'm assuming I have the correct ps bracket (I traded my 250 brackets for the 350 brackets, not really knowing what I needed) I really can't see the bracket in the photos
1967 Chevelle SS
Old 03-25-2015, 04:37 PM   #8
FirstOwner69
I found these additional photos. They may help. The pressure line I bought is an Edelmann that looks like those Rock Auto has pictured. As far as I can tell your bracket looks correct.
EDIT: Also check out this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=149210
Old 03-25-2015, 06:19 PM   #9
FlameOut
Those photos are perfect. Thanks :-) It looks like I have them routed correct, now I just need to straighten them up a bit and track down that piece to fasten the lines to the frame.
1967 Chevelle SS
