door hinges
I need to replace the door hinges on my 71 C10. What I am looking for is feedback/reactions/information on the aftermarket hinges out on the marketplace.
There must be dozens of truck owners that have purchased and used these parts. Do they fit well? Do they work well? What (if any) are the problems you encountered in installing them? What source did you use for them? Did you find one source better than othes? Any and all information is appreciated. |
Re: door hinges
Unless they're bent...you can likely get away with replacing the pins and bushings vs entire hinge replacement.
Re: door hinges
X2 on what Molberg said. i used my old hinges and put new pins and bushings in them. Nice n tight now. save yourself some money.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
Re: door hinges
ok.....but what about the mechanism in the top hinges? That's the little brake system that holds the door open and helps keep it open. Has anyonr ever replaced those parts of the hinge.
I have two sets of hinges....the ones on my truck (which seem to have good pins and bushings) and a set I got for in a lot of parts. I'd like the doors to stay open when they get that way!!!! |
Re: door hinges
Unless your pads are worn away; I stuck a large flat blade screwdriver in-between the two flat bars that the friction pads rub on and twisted thus spreading them apart. works good again.
#6 | |
![]() Join Date: May 2014
Re: door hinges
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Re: door hinges
Re: door hinges
There was a fix in a thread about 6 months ago, they replaced the friction pads with something.. Now i wish i saved it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: door hinges
The PO of my '72 backed up with the driver's door wide open and caught a tree, mangling the door skin, popping out and losing the door check, and possibly tweaking the hinges. Since I'm gonna have to replace the door anyway, replacing the hinges isn't the worst thing.
At least the passenger door only needs new pins and bushings.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
Re: door hinges
OK....so far no one has mentioned that they have ever purchased the new door hinges that are made off shore. So with that being said, there's no feedback to my original question about whether these off shore made hinges are good or bad.
Anyone out there that has bought the off shore hinges and used them care to comment??? |
![]() Join Date: Dec 2013
Re: door hinges
I purchased upper hinges for mine from Truck and Car Shop. I have never liked them and I am rebuilding my originals. Doors don't close right as there is not enough clearance for the factory bolt heads between the hinge halves when closed. Find some originals or fix yours. My 2 cents.
