Old 03-27-2015, 08:54 AM   #1
7tee
7tee's Avatar
Tach location...
Would like to see some pics of steering column mounted tachs and how to attach them. I've been getting the itch to get one...thanks Ed
7tee is offline   Reply With Quote
Old 03-27-2015, 09:02 AM   #2
Swar
Swar's Avatar
Re: Tach location...
I attached mine with a hose clamp. Kind of a for now thing, but it doesn't look bad.
Swar is offline   Reply With Quote
Old 03-27-2015, 09:05 AM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
Here's mine...
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 03-27-2015, 09:13 AM   #4
Possmguts
Possmguts's Avatar
They just come with a big hose clamp... its not a pretty setup... but it works I guess.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-27-2015, 09:34 AM   #5
EARNHARDT#3
Yeah it's pretty crappy. But I like it because it's just how someone would've slapped one on it back in the 70's or something. I had originally purchased an old 70's sun tach but it didn't work. So I bought a brand new sunpro. It looks mostly the same. I could've swapped the internals into the old housing but I didn't feel like possibly ending up with 2 bad tachs LOL
Old 03-27-2015, 09:40 AM   #6
Possmguts
Possmguts's Avatar
I yanked the one I had in mine. The new carrier will have a tach in it. I didnt want to re-use it on a new column because of how they scratch it up and covers the center of the cluster where the turn signals and warning lights are. If I had to do an add on I would rather dash mount it or maybe mount it on the windshield pillar. One would think that after all the years they have been making them they would have come up with a better mounting system by now.
Old 03-27-2015, 09:58 AM   #7
zibs71
zibs71's Avatar
Heres where I put mine
zibs71
zibs71 is offline   Reply With Quote
Old 03-27-2015, 01:57 PM   #8
EARNHARDT#3
From the drivers seat mine doesn't obstruct anything. It only blocks the hole where a tach would be in the cluster.
Old 03-27-2015, 12:45 PM   #9
bigmac73
bigmac73's Avatar
why would you guys just not do a upgrade to a OEM style in dash tach, it does not take long to install one
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-27-2015, 01:36 PM   #10
michael bustamante
michael bustamante's Avatar
cost.
1967custom
michael bustamante is offline   Reply With Quote
Old 03-27-2015, 12:55 PM   #11
Swar
Swar's Avatar
I'm personally not a fan of the stock tach. The double digits look weird. That's just me though. I'd like to find a retro looking tach to fit in the dash eventually.
Old 03-27-2015, 12:59 PM   #12
Possmguts
Possmguts's Avatar
Personally Im going with this setup except Ill be using the full sweep gauges instead.
Old 03-27-2015, 01:03 PM   #13
justin4260
justin4260's Avatar
were did you get that? how much was it?
justin4260 is offline   Reply With Quote
Old 03-27-2015, 01:10 PM   #14
Possmguts
Possmguts's Avatar
You can buy the full setup or piece it together for a few bucks less.
The full sweep gauges and the carrier is costing me about 1100 bucks I think all said and done.
Ebay the c10 gauge cluster and they come up with all different gauge packages.
Old 03-27-2015, 01:11 PM   #15
justin4260
justin4260's Avatar
holy crap $1100 for a gauge cluster? it better be really carbon fiber and silver gauges lol
Old 03-27-2015, 02:23 PM   #16
bigmac73
bigmac73's Avatar
if you are going to spend that kind of cash at least go with these guys and not some EBAY stuff, plus that carbon fiber gauge panel looks weird
http://shop.classicinstruments.com/1...-truck-package
Mike
Old 03-27-2015, 04:33 PM   #17
sKnNyPpY
sKnNyPpY's Avatar
Cheap and easy, used Advance Auto's online discount and picked up in store...until I restore my gauges and add factory tach.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
