Old 03-27-2015, 07:56 PM   #1
jimmy1955
270 oil Pressure readings correct?
Hello, I just changed the oil in my 55 270 and wanted to check if these oil pressure readings are correct/ normal. Upon initial start have between 50-60. Once I drive it for a few miles and it gets hot drops to about 15 at idle and back up to 40ish on acceleration. These readings are with an aftermarket gauge.
Any guidance always appreciated.
jimmy1955 is offline   Reply With Quote
Old 03-27-2015, 08:13 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 270 oil Pressure readings correct?
That's not bad, It just says your motor is showing some wear. 1 lbs per 100 rpm is acceptable.
Old 03-27-2015, 09:57 PM   #3
jimmy1955
Great thanks
Old 03-29-2015, 10:58 PM   #4
SCHRUMGMC
SCHRUMGMC's Avatar
Mine is 40lbs at idle and 35lbs at accelerator? Guessing that is really good
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
