Old 03-28-2015, 03:32 PM   #1
toms68cst
toms68cst's Avatar
Cold starting/running problems
Hey all,
Lately I've been having trouble with my truck in the colder weather. It's always coughed and back fired quite a bid driving it in the really cold weather but it would get by.
Lately, I can't even get it started or keep it running in the colder weather. However if it's more than 60 outside or so it seems to start right up and run like a top. It's kind of weird.
I am not sure if it's carburation or electrical. I kind of suspect carburation. It's a stock 4b Rochester carb.
Any ideas on where I should start or some basic checks?
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 03-28-2015, 04:28 PM   #2
justin4260
justin4260's Avatar
Re: Cold starting/running problems
check your choke. do you have an auto choke or a manual?
justin4260 is offline   Reply With Quote
Old 03-28-2015, 04:39 PM   #3
toms68cst
toms68cst's Avatar
Auto choke. It is closed when cold. It also has stock distributer.
Old 03-28-2015, 05:20 PM   #4
cdowns
cdowns's Avatar
stock distributor as in pointsand condenser?? set the points for the proper gap and or dwell
Old 03-28-2015, 07:07 PM   #5
hamjet
hamjet's Avatar
Sounds like you have to adjust the choke rod or the vacuum break for the choke.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
