03-29-2015, 07:11 PM | #1 |
80 c30 went from no start to full throttle
Was needing to just move a trailer with my truck and spent 2 days on it and finally it starts and goes straight to full throttle and all the butterfly valves are nearly closed the only way to throttle it down is to use the choke. Need some help here guys cause I'm scratching my head here.
1980 chevy c30 6.2L diesel swap here's the build thread http://67-72chevytrucks.com/vboard/s...=1#post7161431 1995 chevy c3500 6.5L diesel 1997 land rover disco I 6.2L diesel swap, MPG rumored at 26-28
03-29-2015, 07:17 PM | #2 |
Re: 80 c30 went from no start to full throttle
Idle screws set wrong?
03-29-2015, 07:26 PM | #3 |
It ran previous to this encounter.
03-29-2015, 08:39 PM | #4 |
What kind of carb you have on it?
Edit: wait just saw your signature that this truck is a diesel? |
03-29-2015, 08:46 PM | #5 |
if its diesel there are no butterflys there.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
03-29-2015, 09:56 PM | #6 |
03-29-2015, 09:58 PM | #7 |
Not a diesel yet. Carb is a quadrajet.
03-29-2015, 10:02 PM | #8 |
The only thing that I changed was get the rear two butterfly valves unstuck.
03-29-2015, 10:17 PM | #9 |
Did you have the carb off ? Are the secondary butterflies catching on the base gasket ? Any vacuum hoses disconnected or split / cracked ?
I know the "VOICES" aren't real but they have some great ideas. 1978 GMC Sierra Classic C25 1983 Datsun 280ZX Turbo 1997 Chevy Cheyenne K2500 1999 Polaris Sport 400 |
03-29-2015, 10:43 PM | #10 |
No I don't have the carb off. No the valves are not catching. Almost new hoses.
03-30-2015, 06:45 AM | #11 |
It still sounds like the secondaries are sticking open to me. I have had it happen to me several times when the carb has been sitting for a couple years.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-30-2015, 08:59 AM | #12 |
What should I do to fix it.
03-30-2015, 10:10 AM | #13 |
03-30-2015, 08:05 PM | #14 |
The part I was talking about is that lever behind the throttle lever. If that sticks open 1/4" your engine will rev pretty high. Just make sure it is moving smoothly and not hanging up or dragging before closing all the way.
FWIW when I see s Qjet with missing pieces I know some hack has been playing with it and would be looking for another one. I have bought a few carbs on ebay much better than yours for under $50. You may get lucky with yours though and hopefully somebody just tossed the rod and everything else is ok.
03-30-2015, 11:50 AM | #15 |
Here you go.
03-30-2015, 12:03 PM | #16 |
A bit closer on both sides would help!
03-30-2015, 01:41 PM | #17 |
That carb looks WORE OUT. I thought my old one was bad.
Probably would not hurt to rebuild this one. |
03-30-2015, 02:54 PM | #18 |
78K & 79C Jimmys
can you see the butterflies after it starts?
any spring tension to hold the secondaries closed?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-30-2015, 05:16 PM | #19 |
My dad says that we're going to rebuild it.
03-30-2015, 05:36 PM | #20 |
Where should I buy a rebuild kit.
03-30-2015, 06:05 PM | #21 |
Here's some better pics.
03-30-2015, 06:09 PM | #22 |
03-30-2015, 06:13 PM | #23 |
03-30-2015, 06:48 PM | #24 |
Where's your secondary air valve dampner rod?
03-30-2015, 07:42 PM | #25 |
It's gone truck came that way.
