Just like to part out trucks!!
Wiring harnesses alot of them
I have under dash harness's for ac and non ac trucks, most are 71-72 chevy, one 68 chevy, one gmc. I have front harness's for 71-72 chevy, 68 chevy and a 71 gmc. I have motor harness's. I have some 71 only under hood harness's.
the under dash ones are $38 shipped each the front ones are $32 shipped each motor ones are $25 shipped each PLEASE READ!!!!!!!!!!!! None are perfect, some may have a few splices but not all hacked up, I cut the ends off and throw away the bad ones.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 04-05-2015 at 08:15 PM. |
Re: Wiring harnesses alot of them
111
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Do you have a pigtail for the rear light harness that goes thru the firewall? PO cut this off.
Yes I looked, I don't have any right now, sorry
I need a under dash for a 71 auto non A/C with gauges wiring harness ?
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
![]() Join Date: Mar 2013
I need a 72 under dash A/C, gauge, manual transmission harness and a SBC engine harness with A/C, manual transmission.
Undone, I'll look on on of those
Seanext, sorry these are all automatic harness's Thanks Randy
![]() Join Date: May 2012
Randy, I could use a a/c harness for my 71, but don't know what to ask for. From heater to ac?
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
In the last picture you have two fuse panels. Are either one of those for an A/C harness and is so how much to 28034? I would like the one with the longest pigtail if it is for A/C
![]() Join Date: Feb 2010
I'm looking for an under dash, front engine harness, and the taillight wiring that connects to the firewall for a short bed. Let me know
randy have you ever got chance to look for 72 bb exhaust for a coil spring truck
Mike, I will look
Seanext, sorry I don't remember on those boxes Woodnears, what year truck? rlk, sorry I don't have any BB trucks, only thing I have for a BB is a pass side cab heat shield Thanks Randy
![]() Join Date: Nov 2014
I need a 72 under dash with A/C, manual, and gauges. Tack would be great too. Let me know if you have one and I'll take it.
Thanks, Daymond |
#15 |
Guys sorry was delivering parts most the day yesterday, I will try to get with you all on what I have later today
#16 |
![]() Join Date: Oct 2008
Hi Randy,
I need an under dash harness -- 72 A/C Auto 7 hole dash cluster, no tach Thanks! |
#17 |
Seanext
#18 |
11secss, it has 2 spices going to the brake light switch
#19 |
Mark here is one
#20 |
#21 |
I can tomorrow after work, you can kind of see it in the 2nd pic
#22 |
OK -- I'll take it assuming that's intact
#23 |
I will take the fuse block that does not have the flasher installed. How much shipped to 28034?
Melvin |
#24 |
I'm actually looking for a gauge cluster plug with a section of wire attached so I can restore my dash. It has gauges with Tach but I could use one that has gauges without tach just fine. Do you have a plug like this?
Thanks, Daymond |
#25 |
Hi Randy.
Looking for a engine wire harness. I have a 70 350 auto. Any luck? Thanks. Tim |
