Solder or not to solder terminals
I crimp and solder my terminals and use heat shrink tube on the small plastic piece down onto the insulation of the wiring. My buddy says that crazy, just crimp’em. I can see it taking a longer time to wire, but I also see a better connection. Am I crazy?
Re: Solder or not to solder terminals
A GOOD crimp connection will do as well in most automotive applications. I was going to solder mine until I saw a TV show on constructing a WRC car. The crimped all the wiring, they doing the work said soldering heats the wire and creates a potential breaking point where the solder joint ends. Key are good connectors (not the skinny HF or auto box store kind) and a good stripper that does not cut into the wire and crimper that is designed for the correct size of wire. Klien is a good tool brand to start with.
Hollister Road Co.
If your soldering is of good quality then solder. If you crimp and solder and have a not so good crimp along with a not so good solder it can cause the joint to heat up and melt the solder out.
I only solder joints that may be in the weather portions of a harness that does not get good air flow or a high chance of a wire getting pulled out of a crimp. The crimp has to pass on its own soldered or not. The rest I just crimp and if its a very thin wire I just solder. Shrink tubing is always a good idea |
4:1 Shrink Tube with glue and a good crimp is all I've ever done and had no issues.
I solder all my connections. I use SN63 solder for work and it holds up to 150c and 20gs. If you see solder connections breaking, its either a bad soldering job or poor solder. Id rather solder than be stranded because of wire coming loose from a crimp and not being able to trace it. That's just me.
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
Get rid of the connectors that have the plastic insulation already on them. I used to take the time to cut or pull that plastic off but now buy solder type terminals from Waytec or an electronics store and use StaCon crimpers + shrink tube+ solder as needed. Makes a good looking, strong, weather tight connection.
no oem solders connections, that's good enough for me
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Exactly what I was thinking!
Called my buddy, he’s an EE and work in aerospace, here’s his e-mail.
Almost any soldered joint will last forever if there's no vibration - that's the key. The solder itself isn't what fails; it's the interface point between the copper wire and solder, that's where the wires - not the solder - fail. Always use shrink tubing, and always restrain the wire mechanically so it can't work-harden itself to death. |
Please excuse the ignorant question, but how or what determines a good solder joint over a bad solder joint?
Is it too much or too little heat? Cleanliness? Incorrect/compatible solder to wire metal? Orrrr all the above???? |
Pretty much all the above. If your solder joint becomes brittle it can cause the joint to fail or increase resistance making it bad.
#13 | |
Hollister Road Co.
here is a picture of good bad and ugly http://www.leadsdirect.co.uk/technic...-solder-joint/ The solder should flow into the crimp evenly and not travel into the wire under the insulation. To much heat does this and a dirty part needs much more heat, not enough heat makes the solder look lumpy and gritty looking like it has sand in it. grease, oil, general smegg (technical term for nasty brown stuff of an unidentified nature) will make it look like it missed spots and won't flow evenly. Usually if you use the correct solder and flux you don't have any issues, I use a dip paste flux and tin the wire then it almost always flows quickly and evenly and ends up shiny and smooth. The crimps I use have a tin coating on them and I heat them to the point that the tin just flashes over and looks liquid and then apply the solder. |
Really helpful link, makes it easy to see what you want and want to avoid.
#15 | |
A clean solder tip is very important, along with a tinned tip and a GOOD solder iron. It's like welding, clean metal, comfortable position, piece clamped so there no movement of it. Last edited by oilslicktg; 04-02-2015 at 04:39 PM. Reason: left thoughts out |
#16 |
Cruzin
when i build it i solder it most of the time, solder and shrink wrap is a clean look. i hate a bunch of crimp connects all over the place i like clean, reliable wiring, but i do on refrigeration equipment for a living
![]() and know how to use them
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#17 |
Actually that is not always true. I work at a GM dealer and we currently have an air bag recall. The fix is to remove the plug under the seat and reconnect wire's with a crimp and solder. Apparently GM thinks there are situation's where a soldered connection is best. Having said that most all connections are crimped
Gregg |
#18 |
I use the crimp connectors with the shrink wrap ends for all my outside the cab connections. All in one solution for me
#19 |
Not many people, even those trained to do so can solder properly. You need good materials, prep, and technique, or you get cold (resistive) connections. Some percentage of cold joints happens regardless. The parts being soldered have to not move after heat is removed before things harden or the joint will be cold.
There are dozens of crimping tools. Not many people know which is right for a connector. Virtually all production harnesses and other connections using wire use crimped connections. Few bother to support and attach the wiring so it doesn't flop around. Moving connections will fail whether crimped, or crimped and soldered. Before soldering connections should be crimped or have some mechanical bond. Solder has no strength--you can bite through it. Since soldering is an additional, often poorly, and/or inconsistently performed step, I would say a properly crimped connection has a better chance of being reliable. |
#20 |
I absolutely don't use insulated single-crimp connectors. I think they are junk and unreliable.
I use only uninsulated ones and crimp, solder and cover with adhesive-lined heat shrink. Example: ![]() I don't however solder Weather-Pack or Metri-Pack double crimp type connectors. They are a very reliable design and don't need soldering. Last edited by roger55; 04-04-2015 at 12:02 PM. |
#21 |
As far as high dollar connectors, Metri-Pack, Weather-Pack or any connector that can be doubled crimped, I agree buy the best tool and follow their instructions, no need to solder.
I'm referring to those Ring Type (I use them a lot as do other car guy's) as I refuse to use a butt slice, male and female quick disconnects or the fork type. OEM have used a great double crimp, it crimped the bare wire and the insulation as on the Coil, Starter, Voltage regulator and the Horn relay as of old and no they didn't solder, but it made one tuff connection. When the Alternator came about, connectors came about, along with bulk head wiring harness and fuse holders mounted to the firewall, made life simple. I think this thread has bee a great amount of knowledge. I just wish that someone would come up with a better ring connector, a Double crimp would be nice and heat shrink. |
#22 |
It's alsways something.....
![]() Join Date: Nov 2008
I only solder and shrink wrap connections.
I realize that many OEM don't soldier- but-they have connectors and crimp equipment that I don't have. I think their considerations are also that crimping is faster than solder and shrink- and in a mass mfg process this is important. With what I have available- solder and shrink wrap is my best option. Just my opinion and experience after 40 years. YMMV
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#23 |
Instead of using heat shrink tubing over a connection, especially one that may see some moisture, I coat the connection with Liquid Tape and never have to worry about corrosion. A must for chassis and trailer wiring.
"Built- not bought" 1958 GMC 150 4x4 in progress 1980 K20- Restored 1985 K3500 Flatbed 58 GMC 4x4 build thread: http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675 |
#24 |
The adhesive lined heat shrink will seal out moisture. It's all I use. See the photo I posted earlier.
