Gasket overlap?
Should this oil pan gasket for my 230 overlap like this or am I sposed to trim it a little before install?
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
Re: Gasket overlap?
it goes under the rubber note the taper
Re: Gasket overlap?
Felt under the rubber, got it! Thanks for the reply!
Re: Gasket overlap?
if you ever do it again this is what you should use instead of what you have, https://www.google.com/webhp?sourcei...00396663018685
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#5 | |
Re: Gasket overlap?
#6 | |
Never Ending Projects
Re: Gasket overlap?
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Gasket overlap?
You do know you don't attach the gasket to the pan, don't you!
Put it on the block and then put the pan on. |
