Old 04-03-2015, 02:42 PM   #1
liftlawssuck
liftlawssuck's Avatar
Windshield Install question
I have searched the archives and found many tips and tricks but alot of different methods.
Do you need to put a sealant down first before installing windshield?
I have a new windshield, new rubber seal from GM, and the whole cab was stripped and painted. So the windshield area on cab is like new. The rubber seal is the 2 piece kind having that lock ring to install after.
So again. Do you need to seal the gasket in place?
Any other tips would be helpful.
Thanks, Brian
liftlawssuck is offline   Reply With Quote
Old 04-03-2015, 06:15 PM   #2
TKCR
TKCR's Avatar
Re: Windshield Install question
I don't believe you do.
https://www.youtube.com/watch?v=wtmeTSvwaTw
TKCR is online now   Reply With Quote
Old 04-03-2015, 06:24 PM   #3
liftlawssuck
I've watched that before. At 5:21 it says they are doing a dry install with no sealant for video purposes. But I don't if you need sealant when everything is new or just need it for replacement.
Old 04-03-2015, 06:30 PM   #4
TKCR
TKCR's Avatar
I guess I didn't catch that part. I know when I watched it before, I took it you didn't need the sealant. But thinking about it, you would need it to keep the water out, because water will find away around that rubber seal.
Old 04-03-2015, 07:07 PM   #5
Liberty
Liberty's Avatar
It certainly can't hurt.
Liberty is offline   Reply With Quote
Old 04-04-2015, 02:13 AM   #6
bilfman
bilfman's Avatar
Doesn't need sealant.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-04-2015, 03:30 AM   #7
Lil Ape
We didn't use any sealant when we did mine. Somebody had used blobs on sealant in the lower corners previously, and over time, water settled there and put large rust holes in the body underneath the weatherstripping.
Lil Ape is offline   Reply With Quote
Old 04-04-2015, 11:33 AM   #8
hatzie
Moderator
hatzie's Avatar
I use Sil-Glyde on the seal but no "Sealant". I don't get leaks unless there are other issues like rust holes.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-04-2015, 02:29 PM   #9
liftlawssuck
Great thanks guys! I'm going to install it without sealant. It's not like it's going to see any weather anyways.
Thanks!
Old 04-04-2015, 09:24 PM   #10
wideopen1967
wideopen1967's Avatar
No sealant. But you will need this tool and a lot of patience for the locking strip, Lisle 47000, Amazon.com: Lisle 47000 Windshield Locking Strip... Amazon.com: Lisle 47000 Windshield Locking Strip...
wideopen1967 is offline   Reply With Quote
Old 04-04-2015, 09:25 PM   #11
wideopen1967
ANd this one, CRL General Purpose Windshield and Back Glass... CRL General Purpose Windshield and Back Glass...
Old 04-04-2015, 11:05 PM   #12
bnoon
I didn't use any special tools at all. Couple of flat blade screwdrivers and some rope.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 04-05-2015, 12:20 AM   #13
hatzie
Moderator
hatzie's Avatar
The glass and gasket can be installed with a piece of string and a plastic spudger.
wrap the string around and pull straight in.
The locking strip is all kinds of fun.
Old 04-05-2015, 04:19 PM   #14
bnoon
I used a wide flat blade screwdriver with spray lube on it and it worked almost as easily as the special tool. All you have to do is spread the opening with the wide flat blade, and follow closely with the other hand and press the locking strip in place. I think the whole windshield change out on my '86 took a half hour and that was taking pictures along the way. I was mad at myself for putting it off for so long because I thought it was going to be a major fight and it wasn't at all.
Old 04-06-2015, 09:57 PM   #15
esbstuff
Factory installed with no sealant. LMC has a nice tool for 12 bucks (?) that makes installation a breeze.
esbstuff is offline   Reply With Quote
Old 04-06-2015, 10:29 PM   #16
73kay
Wink Re: Windshield Install question
I installed the windshield today without the tools. Pain in the ass but I got I got it done. One thing that I had a problem with was the bottom of the glass not seated completely on the bottom which made the top part a little challenging but its in. Next time I'll use the tools maybe...
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 04-10-2015, 06:08 PM   #17
liftlawssuck
So I ordered the tools and they should be in next week. Would installing using rope be best or not using rope? I have seen videos on both and both don't seem too bad.
Old 04-10-2015, 11:33 PM   #18
73kay
One of the videos I saw said to
Have the rubber installed on the perimeter of the cab and then work with the glass from the bottom up. It worked for me but I had to patient with the top corners.
I did try to put it on the window at first and there was a lot of slack and it honestly was getting frustrating and not to mention working with tape, rope etc. but that's how I did it and I was a first timer without the tools. I'm so cheap. Lol
Andrew
1953 3100 292 T5
Old 06-21-2015, 09:07 PM   #19
liftlawssuck
So I finally got around to installing windshield. It went really well. Although I didn't get the locking ring in yet. The windshield is in! The hardest part was putting the new seal in. Was a royal PIA! The glass was easier than I thought it was going to be. Like someone mentioned before. I was hesitant all these years and never dove into it. But now that I have. It's a piece of cake. The plastic sticks I bought were the best investment. Hopefully the lock ring goes just as easy.Thanks for all the help. Will keep you posted on the lock ring.
Old 06-22-2015, 09:00 AM   #20
Speeding Dakota
Speeding Dakota's Avatar
Hello all, I'm at the point I need to install my wind shied and have a question
I have done the rear with the rope method many times, but am curious is the wind shield easier with the rope method (seal on the glass then install to cab) or where you put the seal on the cab and then install the glass in the shield with tools?
Just curious which method to use as I do not have the tools and will get them if that is easier.
Chris
Speeding Dakota is offline   Reply With Quote
Old 06-22-2015, 11:33 AM   #21
liftlawssuck
Chris
I was like you. I have installed many back windows before. Never with rope though. For the windshield I put the seal in first then put the glass in and worked it in. I didn't want to mess with rope. I only used the plastic sticks to help. If you follow one of the links above. You will see "what other people have bought" and that's where I saw them. They worked out great. I haven't gotten to the locking ring yet so I can't comment on that. It went way easier than I thought.
Just be patient on the top corners. I used about 8 of the plastic sticks to pry like a bike tire going on a rim. Then with pressure it popped right in.
