Old 04-04-2015, 11:56 AM   #1
FamilyBowTie
What (used) steering column did you use on your 47-53 ?
Looking for options on steering colums.
I've seen the ones on ebay but would like to know if there are ones I can look for at the local pull a part.
Please post pics if you have them also.
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 04-04-2015, 03:26 PM   #2
nvrdone
Re: What (used) steering column did you use on your 47-53 ?
Try a first gen jeep cherokee
nvrdone is offline   Reply With Quote
Old 04-04-2015, 03:56 PM   #3
Big Daddy Bear
Big Daddy Bear's Avatar
Tagging along to see what comes up...
Big Daddy Bear is offline   Reply With Quote
Old 04-04-2015, 06:57 PM   #4
donandal
1992 GMC 2500 van...with tilt.
length was good,just added flange at bottom
to bolt to firewall.
rebuild parts for signals, switches etc. readily available
donandal is offline   Reply With Quote
Old 04-04-2015, 07:32 PM   #5
Ricos54
Ricos54's Avatar
Summit racing stainless steel/tilt steering column made for our truck $359
Ricos54 is offline   Reply With Quote
Old 04-05-2015, 12:07 AM   #6
oldman3
oldman3's Avatar
Hey Rico, I used a 78 Chevy Caprice tilt column, cut off the column shift stub and filled. Here's a couple pics....Jim
oldman3 is offline   Reply With Quote
Old 04-05-2015, 04:50 PM   #7
lv2tri2
This column came out of late 60s Caddy. Telescopic, tilt, turn and emerg. signals. No ignition or column lock.[ATTACH]
[/ATTACH]
lv2tri2 is offline   Reply With Quote
Old 04-05-2015, 07:08 PM   #8
va4cqd
80s s10
va4cqd is offline   Reply With Quote
Old 01-19-2016, 12:06 PM   #9
FarmerSid
FarmerSid's Avatar
Bringing this back up for some more ideas
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-19-2016, 02:14 PM   #10
Zach B
Zach B's Avatar
73-87 columns get used a lot I think. They may require a little modification to fit though
Zach B is offline   Reply With Quote
Old 01-19-2016, 03:34 PM   #11
HUSSEY
HUSSEY's Avatar
I think most modern columns don't look very good unless a shroud of some sort is build around them like Oldman3 did. I initially tried a column out of a 67-72 Chevy truck but thought it was to long. I thought about shortening it but in the end I ended up getting a plain steel Ididit column from Jegs shipping included for $349 and I'm very happy with its quality.
Guess that's not what you were asking but that was my experience.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 01-19-2016, 05:11 PM   #12
Hampshire
Hampshire's Avatar
Ditto - looks & works great
Hampshire is offline   Reply With Quote
Old 01-19-2016, 05:49 PM   #13
Katrina/10
Katrina/10's Avatar
Chevrolet van column up to 81 fits in the original dash brackets.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-19-2016, 09:59 PM   #14
47 Fasttoys
47 Fasttoys's Avatar
Stock, yes it's used, cut down, new bearings top and bottom, cheap turn signal switch. Not real fancy but real effective.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-30-2016, 10:34 PM   #15
jhnpldng
jhnpldng's Avatar
I used a stock column in my 64 and had it hooked up to a cable shift 4l60e. It was an automatic column which are pretty rare for a 60s truck. But it was skinny so it didn't look out of place and prob wouldn't look out of place in a 47-54. I never did get around to making a new gear indicator for the OD 4l60e but it wouldn't have been too hard. Just clear plexiglas with white letters. I've still got the column if anyone wants a pic of the column shift bracket. I mounted the bracket to the column using existing bolts. I used the existing ign switch but since there wasn't enough circuits, I had to add a relay. Never had a nice wiper switch figured out. Turn signals were the same. Yellow, green etc.
One downfall to a 60s column is that it's not collapsible.
jhnpldng is offline   Reply With Quote
Old 01-30-2016, 10:48 PM   #16
chopit
chopit's Avatar
The PO of my project modified the original and planned to use the 3 sp column shift for the automatic for nostalgic look. Haven't decided if I am going to continue in that direction.
chopit is offline   Reply With Quote
Old 01-31-2016, 01:01 AM   #17
jhnpldng
jhnpldng's Avatar
Hey, there's an idea in there somewhere. A kit to modify the old three on the tree columns into auto columns.
Collecting is the easy part. Get er done!
Old 01-31-2016, 01:10 AM   #18
chopit
chopit's Avatar
The only disadvantage I see so far is you don't have a visual indicator for what gear you are in. I've been driving long enough it wouldn't matter to me lol. Might trip some people out.
Old 01-31-2016, 09:39 AM   #19
am0254338
I'm using a 67-72 column in mine. No ignition tumbler in them. They are almost identical in length to the original. Turn signal and same gear indicater as a lot of these after market columns available. They even fit although snuggly in the original column bracket on the dash. Mine is not tilt though.
am0254338 is offline   Reply With Quote
Old 09-25-2017, 07:50 PM   #20
Khaus
Khaus is offline   Reply With Quote
Old 09-25-2017, 07:52 PM   #21
Khaus
Do you have any pictures? I've heard these columns are longer. Want to see how you mounted it and how it fits.
Old 10-08-2017, 10:07 AM   #22
Matt_50
I have a 80s c10 column collecting dust but after seeing one up close in a 52, it just doesn't look right. Definitely works but if you want a stock look try something like out of a late 60s truck. I got my hands on a 55 bel air column with auto shift. Mocked it up. Looks awesome. No tilt though, and I gotta fab a bottom bearing. The new kits look great.. But i don't know about you but my budget is too tight lol.
Matt_50 is offline   Reply With Quote
Old 01-31-2016, 02:10 PM   #23
_Ogre
_Ogre's Avatar
while the new aftermarket columns are nice, any oem column will give years of service
stay away from the offshore columns with tilt as they have bad reputations for failure
truk has an astro van column in it, same as s10 column, cost me $35
junkyards are full of columns for cheap, the only issue is you need to make a cover
oldman3 made a pretty sweet cover on his posted above
this is the cover i made for the astro column
shop air compressor timer
Old 02-01-2016, 09:44 AM   #24
Cautrell05
About 20 years ago I built this one for a customer. Used a mid 80s chevy van column. tilt, wipers, ignition, column shift with a gear indicator. Using the same thing on my 47 build.
Nick
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 02-01-2016, 11:22 AM   #25
_Ogre
_Ogre's Avatar
^^^ same looking column in my truk, 86 chevy astro/gmc safari van
doesn't look bad without the cover
it all depends on the level of finish you do to your truck
