04-04-2015, 09:11 PM | #1 |
68 3rd seat belt point mount location?
My interior is upholstered and I would like to find the plug on the first try.
04-04-2015, 10:28 PM | #2 |
Re: 68 3rd seat belt point mount location?
Im not sure if mine is stock or not but it uses the same mounting location
as the passenger and driver. |
04-05-2015, 08:15 AM | #3 |
What I need is the dimensions for the location of the upper bolt mount for a three point seat belt.Mine are under upholstery and I would like to hit the hole the first time.
04-05-2015, 08:28 AM | #4 |
If its cloth try using a needle to find it.
04-05-2015, 10:20 AM | #5 |
Old member
Most of them I have seen have a plastic cap over them. Maybe hard to find with the needle trick.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-05-2015, 10:26 AM | #6 |
By pressing hard with your finger and moving it around the area I would think you could either feel the caps or the holes (whatever the case may be) through the fabric. They're not super small.
