04-05-2015, 04:41 PM | #1 |
thick or thin?
Oil pan gasket that is... so several different places on the net say measure the front seal area and if its 2 1/4" its thin, 2 3/8" its thick... Wellll, my pan is 2 5/16".
I'm thinkin' just load her up with RTV and call it a day... It's a late 60s early 70s 307, and i already bought a thin one piece felpro gasket from jegs... Also, do I need longer bolts with a one piece gasket? it seams like only a few threads thread into the block.
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!) |
04-05-2015, 06:10 PM | #2 |
Re: thick or thin?
I'd say get the thicker gasket. Don't ever load it up with RTV. That's a .... well it's a rigging.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
04-05-2015, 06:23 PM | #3 |
Re: thick or thin?
well said! but that about the longer bolts?
04-05-2015, 06:28 PM | #4 |
Re: thick or thin?
Generally you want the thickness of the bolt equivalent worth threads threaded in. So if the bolt is 3/8" thick 3/8" worth of threads should be in.
04-05-2015, 07:24 PM | #5 |
Re: thick or thin?
Thick will help solve all the leaks of a Chevy Engine...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
04-08-2015, 10:29 AM | #6 |
Re: thick or thin?
RTV is not always your friend. A thick style gasket is so much easier than having threads of RTV snot clogging up oil pickups and suchlike.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
04-08-2015, 10:33 AM | #7 |
Re: thick or thin?
Felpro has a one piece silicone gasket for both two piece and one piece rear mains, it also has metal stiffeners in the rails to prevent over torque.kind of pricey though, about $35+
Ben |
04-08-2015, 12:24 PM | #8 |
Re: thick or thin?
That's the one I would buy!
04-08-2015, 10:46 AM | #9 |
Re: thick or thin?
What Ben said....
04-08-2015, 12:45 PM | #10 |
Re: thick or thin?
The FelPro is worth the $$$, it's pretty much set-and-forget.
04-08-2015, 02:07 PM | #11 |
Re: thick or thin?
put one on my 383 build
Ben |
