Old 04-06-2015, 10:44 AM   #1
riz
79 and 81 frame differences ???
I have an 81 C10 short box project and I found a 79 frame for cheap in great condition.......... are they the same frame? Would I run into problems trying to put all the 81 stuff onto the 79 frame? I don't want any extra work. Thanks in advance.
RIZ
riz is offline   Reply With Quote
Old 04-06-2015, 11:13 AM   #2
77c10
77c10's Avatar
Re: 79 and 81 frame differences ???
One difference that I know of is the front frame horns where the bumper mounts. There may be more but that's all that I'm aware of.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 04-06-2015, 12:30 PM   #3
69heavychevy
69heavychevy's Avatar
Auto trans cross member is different. Fitting a 73-79 cross member on an 80-87 frame requires spreading the frame a bit and drilling an extra mounting hole. Only really necessary if you want your dual exhaust plumbing to be routed a little cleaner.
In your, case it would be easiest to just get the correct year cross member.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 04-06-2015, 04:53 PM   #4
KrazyRay
KrazyRay's Avatar
The 79 frame uses different cab bushings. You might have to oblong a hole for the rear sport bumper. You will need to cut off the frame horns for the front bumper brackets.
KrazyRay is offline   Reply With Quote
Old 04-06-2015, 09:48 PM   #5
esbstuff
You do not need to trim the frame horns... never!
esbstuff is offline   Reply With Quote
