Old 04-06-2015, 12:07 PM   #1
Figuarus
Figuarus's Avatar
S-10 Brake upgrade?
Hey guys, I recently dismantled my 96 S10 Blazer and have a brake master cylinder and booster. I was thinking about mocking it up and maybe using this for a cylinder/booster upgrade.
My question is this: since the MC in the truck is the single line small resi style, and if i could get the Blazer MC to work, Would I connect the hardline to the front or rear port on the New MC?
This is what the MC looks like:
http://www.oreillyauto.com/site/c/de...+brake+booster
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 04-07-2015, 12:41 AM   #2
Captainfab
60-66 Nut
Re: S-10 Brake upgrade?
The S10 booster is one of the boosters that is compatible with my booster brackets.
When you change to a dual reservoir master cylinder, you must convert your truck to a split brake system.
Old 04-07-2015, 11:58 AM   #3
Figuarus
Figuarus's Avatar
PM Sent.
2013 Malibu LTZ
Old 07-31-2015, 10:28 AM   #4
superfly66
How did the S10 booster work out? I was thinking of using an S10 booster.
superfly66 is offline   Reply With Quote
Old 07-31-2015, 03:23 PM   #5
Figuarus
Figuarus's Avatar
I'm still ironing out the kinks of doing the job as it's my daily driver, but with the right bracket, it'll work just fine.
2013 Malibu LTZ
Old 07-31-2015, 05:55 PM   #6
Keith Seymore
Keith Seymore's Avatar
Is your truck disc/drum or drum/drum?
The S truck master cylinder is for a disc/drum system. The larger port and reservoir go to the front system, since the disc require more fluid displacement for operation.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-31-2015, 06:18 PM   #7
Northwest Outlaw
Northwest Outlaw's Avatar
Following this as I have a 92' s10 that may need to become a donor vic...
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 07-31-2015, 08:26 PM   #8
joedoh
joedoh's Avatar
the 96 s10 blazer uses the same MC as the s10 trucks, and they are pretty small. A good upgrade is the 98+ blazer MC, its larger for the dual piston front brakes, or even better, a 98+ booster and a 99 fullsize MC
booster, brake, brake booster, master cylinder
