Where could I find the harness that goes from the HEI module to the Cap?
That little three wire harness...where might I find one to buy? Mine has literally come apart, and I'd like to replace it, to be sure it's not my problem.
You should still be able to pick them up @ your local dealership. I had the same problem w/the HEI in my old 'camino & I was able to get one (that was around 95-96 though).
5 day ban, learn to behave.
any auto parts store will carry it.. try "condenser" or maybe pickup coil
mike |
lemme know howmany wires and what style plugs on end and numbers from the housingand illprobably have a good used one
is it the normal 75-79 without ECM control, or doesit have extra wiring harness plug flat style with four wireS? |
