Old 04-10-2015, 10:01 PM   #1
profe56
Please help me to buy the right tires
Hi folks: Please help me to buy a right set of tires.
After 9 years with my C10 69 finally I'm going to buy a new set of tires.
My truck has a 305 eng but in a future I want a 350, 700 trans and 3.42 rearend. I drive my truck 75% freeway 25% city
Rims are 15's
profe56 is offline   Reply With Quote
Old 04-10-2015, 11:15 PM   #2
s_nova69
Re: Please help me to buy the right tires
245 75 15 too open country h/t. Best road tire out there bar none.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 04-10-2015, 11:16 PM   #3
s_nova69
Dang auto correct
245 75 16 toyo open country h/t
Phil
Old 04-11-2015, 07:25 PM   #4
profe56
Thank you: I've 15s rims. Is Toyo Open country brand of tires?
Old 04-11-2015, 07:39 PM   #5
profe56
Yes: I found is brand tires but the wheels are 15
Old 04-11-2015, 11:10 PM   #6
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Personal preference: B.F. Goodrich Radial T/A. - Been using them on all my "hot-rods" for years. Last set on the front of my '70 stepper: 40,000 miles. - Rears : not so "OOPS"
TobyArnot is offline   Reply With Quote
Old 04-12-2015, 12:00 AM   #7
Average Joe
Average Joe's Avatar
It really is a matter of personal preference. I like a taller sidewall, so I look at a 70 series tire. If you like less sidewall you might like the looks of a 50 or 60 series tire. I run 255/70/15 Firestone Indy 500's on my 6 lug rallys and really like the look. The 255 is how wide the face of the tire is. In my case 255mm wide. The 70 is considered the aspect ratio. Basically, a percentage of tire face applied to sidewall height. Im not really brand loyal on tires. I have Cooper Cobra's on my Nova and like those as well. I would browse the many tire and wheel threads on here and that will give you more of a visual idea.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 04-12-2015, 01:07 AM   #8
profe56
Thanks: now can i see pictures with 245/70/15 and 255/70/15?
Old 04-12-2015, 02:08 AM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Coincidentally, I just mentioned that in another post. Here are mine, not a great picture. Personally, I don't like the way they fit in the well. Maybe it's the fact the bed is down to metal, because they look better in front.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-12-2015, 11:12 PM   #10
profe56
Thanks. Because I have 15s wheels I'll take 255/70/15
Old 05-02-2015, 04:08 AM   #11
profe56
Finally, new tires on my truck. Thanks for your suggestio 255/70/15
http://i962.photobucket.com/albums/a.../IMG_09541.jpg
Old 05-02-2015, 10:03 AM   #12
BC10
BC10's Avatar
I'm digging it! My dad has a Longbed stepper and that thing has been hauling hard ever since I can remember.
BC10 is offline   Reply With Quote
Old 05-02-2015, 10:35 AM   #13
leftybass209
leftybass209's Avatar
Mine are 215/75 15's in front and 235/75 15's in the rear. Good clearance and sidewall height even on a 3/5 drop. I used a tire comparison website that shows side by side views of the tires and dimensions.
leftybass209 is offline   Reply With Quote
Old 05-02-2015, 12:39 PM   #14
65 C20
Just as a side note Toyo Open Country have wide grooves and like to pick up gravel alot then spit them out later.
I have a set on mine, that is how I found out.
Also been told that by a few other people.
65 C20 is offline   Reply With Quote
Old 05-03-2015, 03:52 AM   #15
Muncie
Muncie's Avatar
I just bought Toyo Open Country ATII's for my Cummins. As far as the AT's are concerned, I haven't found they pick up as much gravel as the Yokohama AT's. Just my two cents.
1968 C20
2002 GMC 2500HD
Muncie is offline   Reply With Quote
