04-11-2015, 06:43 PM | #1 |
Radiator help.....
Newly purchased 63. Need some serious help with getting the radiator (right)!
As you can see from photos, shroud in front, shroud in back...incorrect mounting......WTF ! I would like some help with a correct size, shroud or no shroud, mounting? new from, hoses from trans, it has a small cooler tie wrapped to the front of the radiator now.......any comments and ideas greatly appreciated. 350, automatic. |
04-12-2015, 01:35 AM | #2 |
60-66 Nut
Re: Radiator help.....
That is the small I6 radiator for the 230/250 engine compounded by the fact that the small block has the long water pump. That fan shroud is something cobbled on there from another vehicle. The shroud between the radiator and the radiator support is factory for the I6 radiator. What you will need is a V8/HD I6 radiator that sits on top of the radiator crossmember instead of down between the frame rails. You will also need the lower saddles to bolt onto the crossmember as well as the correct top support. Then a reproduction V8 fan shroud along with the factory side flashings to bolt the shroud to. Then you will need to move the fan back towards the engine. The fan should be only 1/3 to 1/2 into the shroud. I'm not sure if that is possible with the long water pump. I don't use long water pumps in these trucks.
04-12-2015, 03:07 PM | #3 |
No, look closely; IMHO it looks like it might be the large/"V8" radiator wedged into the small radiator location.
04-12-2015, 01:39 AM | #4 |
Not exactly sure what you have there. Im not very familiar with that set up. I think that the original may have looked like a 55 gallon drum thats had about 10" cut off and installed for the shroud. I got a fiberglass one from repop places. I think it may have been for a '65? It's fiberglass and needed a little bit of trimming especially for the 21" fan. Mine doesn't have the thing that yours has in front of the radiator either though. Theres a lot of gaps that are going to be letting much needed cooled air out instead of through your radiator.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-12-2015, 01:43 AM | #5 |
60-66 Nut
The original and aftermarket V8 fan shrouds for the '63-'66's are made of a fiberglass/composite material.
04-12-2015, 10:07 AM | #6 |
Ahh, thanks Captain. I do remember them being a little pricey and not wanting to modify mine!
04-12-2015, 11:08 AM | #7 |
Thanks all....What im getting is, I need a correct radiator, mounted in the correct location, and a correct shroud, also a short water pump. ANY advice or recommendations on a new rad, size, etc.... I thought the pump was a short one?.....Any advice on best place for radiator?
I want to do this right. Big thanks to you guys. Need list: radiator mounts shroud fan water pump power steering bracket, (because im changing the pump) ? alternator bracket ??? ( pump change)? belts-correct pulleys ANY thing Im missing ??? |
04-12-2015, 03:18 PM | #8 |
It also looks like a short pump to me.
05-29-2015, 10:04 AM | #9 |
Radiator/Fans/Shroud: http://www.entropyrad.com/1963-1966-...-radiator.html
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
05-29-2015, 10:01 PM | #10 |
One foot in front of the other
Correct set-up should look like this:
