08-29-2003, 10:26 PM | #1 |
Better Valve Cover Gaskets: Cork or Rubber?
Which one should I get to fix my leaking valve covers. I'm thinking rubber...but wouldn't cork swell better? Or is swell bad? Also, which type of Permatex should I use?
Thanks! |
08-29-2003, 10:27 PM | #2 |
It followed me home?
I've always heard the rubber are better, plus you can reuse them
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-29-2003, 11:20 PM | #3 |
i got rubber vavle cover gaskets. there reusable almost indestructable. they are a bit expensive but they dont leak no permatex required .
08-30-2003, 01:28 AM | #4 |
huh?
Do yourself a favor and don't cheap out if you buy the rubber ones. The cheap ass rubber gaskets leak badly, or always have for me. I personally have always stuck with thick cork gaskets. To each his own :p
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
08-30-2003, 01:51 AM | #5 |
The rubber gaskets iam talking about are like aluniumn with rubber coating there and about 3/16 of a inch thick . they are a quality valve cover gasket and cost about 20 dollars. i have took them off half a dozen times with no problem. these gaskets are not cheap and certianly a grade above cork. they are stiff for easy installation but soft enough to seal. cork tend to break for me
08-30-2003, 04:33 AM | #6 |
huh?
hey 78, now that I know what gaskets you're talking about, I'd have to agree that those are better :p I've just had better luck with cork, over the el-cheapo felpro rubber gaskets. My next set will be steel-shimmed rubber, like you have.
08-30-2003, 04:51 AM | #7 |
I like cork, but only the good quality ones. The next-to-last set I put on only lasted 26 years, so I could be wrong.
08-30-2003, 02:05 PM | #8 |
LED King
I do believe Fel-pro now makes vavle cover gaskets in the same material that they do for the one piece oil pan gasket.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
08-31-2003, 07:30 AM | #9 |
me
i have never used anything but cork. the trick to reusing them is before you put them back on. clean them with either carb cleaner or pvc pipe cleaner, and clean the top of the heads. make sure the covers arent dented to deep.
most of the problems with covers leaking isnt the gaskets its either how they are mounted or the covers a messed up in some way by over tightening them. |
08-31-2003, 09:34 AM | #10 | |
Yes they do, and I think that's what I'm going with next. |
08-31-2003, 02:13 PM | #11 |
Cork...
As I'm a kind of a scrooge , they are manufactured by myself... The Baron |
