04-13-2015, 11:00 PM | #1 |
Death Wobble
So today I decided to get some work done on my K5. I replaced the brake pads and since the front tires were off I did a rotation. I made sure that everything was tight and went to town, no problems. On the way home the truck decided it wanted to dance going 40mph and it's stopped at 35mph. When I got home I double checked the lug nuts and the axle nuts, everything is tight and if I lift it up in the air I can't move the wheels by hand (side to side). I'm thinking that the spring bolts might need tightened up, would that cause a death wobble, or am I missing something here? Front axle is an 8 lug 10 bolt with 33 12.50 r 15 bolted to them.
1979 GMC Sierra Grande Crew Cab C25, 454/TH400/4.10-Project truck/ DD 1985 Chevy K5 Blazer 700r4/4.10/8 lug- in search of new engine 1993 GMC Sierra K1500 4L60E 2007 Suzuki Forenza- her DD and the family vehicle |
04-14-2015, 01:36 AM | #2 |
Re: Death Wobble
Sounds like out of balance tire(s) since it started after the rotation.
04-14-2015, 05:23 AM | #3 |
Re: Death Wobble
Like said swap the tires back and drive it,If its not the tires then it could be ball joints or tie rod ends.
04-14-2015, 04:18 PM | #4 |
Re: Death Wobble
Steering damper.
Who needs a Hemi when ya got a Chevy! Last edited by RIDE-RED 350r; 04-14-2015 at 04:47 PM. |
04-14-2015, 04:39 PM | #5 |
Re: Death Wobble
Do you have a track bar?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-14-2015, 08:05 PM | #6 |
Re: Death Wobble
I have a sway bar and the bushings and mounts look new still I just replaced the tie rod ends and found the upper left knuckle joint was loose so I tightened the nut down on it, looks like the PO just got impatient and forgot some things and the unbalanced tires woke the problems up. Now for a test drive to see if I fixed it. I did have the tires balanced and it seemed to help till I hit the dirt road by my house.
04-14-2015, 08:28 PM | #7 |
Re: Death Wobble
Well it seams that I fixed it. There was no wobble what so ever and I got it up to 50 on dirt and 70 on hard ball. Thanks for all the input, it was much appreciated.
04-15-2015, 02:27 AM | #8 |
Re: Death Wobble
A Steering damper would be band aid and mask the true problem.I'm glad you found the problem and got it taken care of.On a leaf spring truck death wobble is kinda easy to pin point something with links and coils like a jeep is a nightmare to pin point.
04-15-2015, 10:00 AM | #9 | |
Re: Death Wobble
Most of the time death wobble boils down to caster related issues. Like lifting a vehicle without compensating for the caster change or bad kingpins or ball joints.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
04-19-2015, 01:33 AM | #10 |
Re: Death Wobble
Would bad sway bar bushings cause this also? My truck started the same thing recently. Nothing has been changed in the suspension or steering and the same tires are still on the front axle. Just started it out of the blue one day and only happens when I hit a bump. Also it seems kind of severe too for it to just be a missing wheel weight.
1978 Sierra 1/2 ton lifted, 388/SM465/NP205, 35x12.50 on deep dish aluminum slot wheels. |
04-19-2015, 01:51 AM | #11 |
Re: Death Wobble
If a missing swaybar doesn't cause it, bad bushings wont either.
Time to go through everything and check. Have someone saw the steering back and forth while you look things over.
'68 C10 SWB '85 K30 Blazer |
04-19-2015, 02:01 AM | #12 | |
Re: Death Wobble
wheel balance or their weights will not cause a death wobble. Which is totally different than a tire out of balance. With that being said out of balance tires can affect a death wobble.
04-19-2015, 02:07 AM | #13 |
Re: Death Wobble
Thanks for the tips. I wasn't sure how bad bushings or a removed sway bar would affect it. First time dealing with a wobble like this. All my other tucks I had have never did it till now.
68' Newtricks- I'll have my dad take a look at it with me when we put the transmission and transfer case back in it. Thanks!
04-19-2015, 02:11 AM | #14 | |
Re: Death Wobble
04-19-2015, 02:21 AM | #15 |
Re: Death Wobble
Im pretty sure it was I cant say for certain though. I was pretty young when my dad lifted it an easy 12 years ago. A fresh alignment has been on my to do list after I correct the steering. My dad had to sell the truck a few years ago after the place he worked for went bankrupt and I recently bought it back. The guy he sold it to probably did something to it and that's the issue cause it was driving fine when my dad had sold it.
04-19-2015, 02:36 AM | #16 |
Re: Death Wobble
Anything and everything that can wear/loosen/or stretch can create or add to death wobble.
Spring bushings rod ends ball joints/ king pins wheel bearings caster, camber, toe (not normally camber/toe, but can add to the "darty" feeling) U-bolts or or broken spring pins (normally broken pins can cause "dog tracking" or wondering loose steering) maybe etc and notice I didn't say steering stabilizer, it just helps soften "jerks", doesn't hide DW
04-19-2015, 02:44 AM | #17 |
Re: Death Wobble
Spring pins make a lot of sense because my steering is awful at the moment but I think a lot of that is due to a bad steering gear.
04-19-2015, 02:46 AM | #18 |
Re: Death Wobble
If ya have any other tips just shoot me a PM I dont wanna take over his post.
04-19-2015, 02:49 AM | #19 | |
Re: Death Wobble
Bad steering "feel", however, has another list entirely
04-19-2015, 02:53 AM | #20 |
Re: Death Wobble
Very true lol
04-19-2015, 06:40 AM | #21 |
Re: Death Wobble
These axles were not designed to run 35"-40" tires and that's a lot of extra rotating mass. Couple that with lifts and other steering geometry changes and then hit a decent bump at 35 mph and boom-death wobble. Steering stabilizers work like shocks. They do not mask the issue-they fix it. Ever wonder why that Chick just flew past you on the freeway with those 40" tires and she seems so stable? Check out the dual stabilizers on her front axle. Sure, all those other things can help to cause it and everything needs to be as tight as it can but when it comes back it can be catastrophic. Get the stabilizers and possibly save a life. You will be amazed at the new ride quality.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-19-2015, 07:46 AM | #22 |
Re: Death Wobble
^good info
Dual stabilizers are on my to do list after I replace/rebuild the steering gear.
04-19-2015, 12:26 PM | #23 |
Re: Death Wobble
Stabilizers don't solve the problem though. As said it just masks it. I had death wobble on mine and threw dual stabilizers at it. Proved just as bad. Once I aligned it properly, new bushings, and made sure the wheels were balanced, death wobble went away. The dual stabilizer also went away and the factory one is working great!
04-19-2015, 07:08 PM | #24 |
Re: Death Wobble
I guess that's why they were installed at the factory level and improved upon and made bigger and better. My stock one worked ok too til it blew out with the big tires. I think that is why they call them S T A B I L I Z E R 's cuz they stabilize the steering by masking death wobble. HMMM. Better to be safe than death wobbling!
04-19-2015, 10:31 PM | #25 |
Re: Death Wobble
I was of the same mindset until dual stabilizers didn't work. There's a lot of people running around with 1,2, or 3 or more stabilizers that still have death wobble. You will be time and money ahead finding and fixing the problem. They are hard to chase down at times, but it is great peace of mind knowing it's done.
