04-14-2015, 10:33 PM | #1 |
Gear Shift problem
I have a 76 Custome Deluxe with the 350 Automatic Trans.
What would cause the gear shift to not lock into place? When I shift from Park to Drive, it does not go into gear. I have to go to 2 or 1 for it to go into gear, then go back up to N and back down to Drive. When I shift from D to R, I have to go nearly to P for it to go into reverse. It just started this a couple of days ago. Is there some linkage I need to adjust. thanks for your help. |
04-14-2015, 11:28 PM | #2 |
Re: Gear Shift problem
Detents in the shifter worn, or linkage worn.
04-15-2015, 07:35 AM | #3 |
I would guess the linkage got out of adjustment.
Other than Park the actual detents are in the transmission itself. There is a cantilvered spring which engages a "roostercomb", and that's what gives you the "feel". Take a look under the truck. You should see a rod that goes down from the steering column to the trans. There's a little "barrel" attachment with a bolt on it. Chock your wheels so the truck doesn't roll. Put the shifter in "N"; go under the truck and loosen that barrel; click the trans lever around until the trans itself is firmly in neutral. Tighten the barrel bolt back up. If that doesn't do it then I would guess something has happened to the spring/roostercomb arrangement inside the trans. Or may e something happened to the cross shaft at the frame, like the spring broke or the half spherical plastic washer fell out. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-15-2015 at 07:52 AM. |
04-15-2015, 09:38 PM | #4 |
thanks for the suggestions.
Everything outside looks fine and is tight. I tried what you said and it did not help, so it must be the spring/roostercomb. what's next? Can I drop the pan and replace some parts? |
04-16-2015, 08:09 AM | #5 |
Yes. You can drop the pan and have a look.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
