![]() Join Date: Feb 2015
Pointing at 1 TDC?
Manifold is back on but distributor points at 5 or just past 1 towards the temp sender...am I missing a spot inmbetween.? 63 283 Thx!
Re: Pointing at 1 TDC?
Sorry on uppy side down
You need to pull the distributer out and re stab it so it aligns with the number 1 plug wire on the cap. Looks like you are a tooth off. Once you pull it out turn it back a bit and re stab. Hard to tell from the pic. I hope this helps.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
It does help I'm just having an issue I think with the new dist gear
You might have to turn the oil pump gear with a long screwdriver to get the proper alignment. It seems like you are in between two cylinders.
Picture of old
I may be...I've been turning it 20 x in and out ...I have the old dist in
Another thing you can do is make that point your number 1 plug and set your firing order from that. Worst case you have to re set TDC and start over. I had this happened before with a different distributer.
Lets help with that pic.....
old on the left, new on the right
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thank you
No problem.
