Resistor-Dumb question
I pulled the heater/AC control to replace the fan switch. I also replaced the relay behind the glove box. Vendor said to replace the resistor at the same time. Where is it? Told you it was a dumb question. TF
huh?
![]() Join Date: May 2000
I *think* the resistor he is referring to is the three-pronged thingamabob on the heater/ac box. But I could be wrong.
TTT
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Inline 69
Resistor Connection
Jeff 5150, Any chance that has 2 blue and 2 yellow wires on the plug? If so, it's inside the box, no wonder I couldn't find it. Tfrog
![]() Join Date: Dec 2002
per 1971 GM Manual.....the resistor pack has 3 wires....Dark Blue; Light Blue and Yellow.......
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
![]() Join Date: Mar 2003
The resistor controls the fan speeds, if you are replacing the switch because of melting connectors there is too much resistance in the blower motor itself, thus creating heat.
I found it
Thanks to all, class 69 GMC Jim, 5150 et al. Unfortunately I got the duct work apart before I go the last post, but I'll change it while it's on the floor now. Thanks for the directioin and for the drawing. I owe you. TF
