rockwell t221 transfercase coupler needed badly
Does anyone know where I can get the coupler that goes in the t-case adapter on a Rockwell t221?
Re: rockwell t221 transfercase coupler needed badly
Used will be your only hope,Pretty much no one makes any replacement parts for those t cases.
![]() Join Date: Feb 2007
I had a few more links bookmarked but I see they are no longer active. Sad, we're loosing out drive train suppliers. Here's a couple anyway. May need to keep an eye out for used as stated. Good luck.
http://quad4x4.com/index.htm http://www.tbtrans.com/transfer_case.htm#chevy_parts
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Thanks guys
Posted via Mobile Device |
Don't know if you found what you needed or if this will even help. My coupler was warn to the point that the seals would no longer seal and 90w would leak into the adapter. Yes there was slop but it still worked and it could not be replaced. The major issue was 90w on everything. The fix. I made gaskets for each side of the adapter and drilled a taped the weep hole in the bottom. This worked until I found a 205.
I might have one from when I swapped from the 221 to the 205. Let me check tomorrow.
It had to be done. |
![]() Join Date: Feb 2014
68 Terry gmc had two very similar posts on 4/19 within a couple of hours. In the other thread we discussed using a NP 205 coupler. It had to be shortened to 3 3/8th inches, the internal teeth had to be machined to match the T221 coupler and a new seal with larger internal diameter had to be used. The National Seal # is 40071s (thank you to Vero 67). I am pretty sure this is the way Terry was going. Jordan I mention this- One,save you digging and two, it may help someone keep their Rockwell rolling without finding the elusive coupler. Bruce
#8 | |
