Old 08-30-2003, 06:09 PM   #1
chiphayes
rear disc brakes
info here,just bought some disc brackets for the rear of my 72, 12 bolt,bought them on ebay,100 bucks.mailed the guy he said they would fit my truck.well they did,after, i redrilled all the holes,none would match up,the ones that were the closest,were to close to the rotor an wouldnt let the bolts for the calipers go on.so i drilled all new holes,had to grind the pi$$ out of them to fit over the axle,and also for the caliper to fit.got rotors for 77 lincoln rear,and had to have the axle hubs turned down.one good note was, i got 2 junkyard calipers for 5 bucks for core charge,and bought 87 iroc calipers and they were only 10 bucks each,but they dont have e brake on them.bad note ,truck has been down for 3 weeks waiting on all the parts,not to sure a kit ,wouldnt be the best way,if i figure the time and aggrevation.wasnt really hard,just everything had to be modified,havent put my foot on the pedal to see if i will need prop valve or not,but i will let you know
chiphayes is offline   Reply With Quote
Old 08-30-2003, 10:06 PM   #2
nu2-72
seller was who? I don't want to go through that>
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
