Step fender bracing
I'm a gas tank away from getting my truck on the road in time for its 50th, and one of the final, non-gas tank pieces of the puzzle is the bracing for the rear fenders.
![]() From what I can tell (thanks LMC), there should be three braces per side; two on each wheel arch that attach to the fender mounting flange, and a third that attaches behind the wheel arches to somewhere. I've figured out three of the four arch braces (and assumed that the side mount spare tire bracketry will come into play on the fourth) but I haven't figured out what the last two braces attach to, if they're supposed to be there at all. These are the pieces I have: ![]() But when I mock them up, they don't seem to line up to any existing holes, but they do happen to line up with the bed wood, meaning nutting and bolting is out of the question. What am I missing? |
![]() Join Date: Aug 2013
Re: Step fender bracing
should be 4 a side one in the back 2 around the arch and one the attaches to area where the step meets the fender and goes through the frame...
i seen its got 66 fenders!!!
on the inside of the fender, there should be an area where the fender meets the back of the step one of the bolts that attach the 2, one is the brace rod instead of a bolt. well that rod has a threaded end that goes through the frame with a nut on the other side...
My 1965 fenders.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Mine connected with a bolt that went through the bed side and through the L shaped peace that is welded to the bed side that holds the edge of the wood down. I reallocated mine to one of the rails that the wood lays on by creating my own brackets out of tube stock with clamped down ends.
![]() ![]() Join Date: Aug 2013
Here is the brace position installed on my 62 ...the third picture is a long 1/4 dr extension sitting were the step brace should go when I score one
[QUOTE=Joe Pass;7142856]Here is the brace position installed on my 62 ...the third picture is a long 1/4 dr extension sitting were the step brace should go when I score one
if you dont find one you can make it, use threaded rod for the frame side, weld it to round stock and weld the bent end that attaches to the fender/step portion, if u have extra rods just cut the end with the smashed area that has the bolt hole and weld it up. thats how i made my side mount spare holder from 2 units to make one!!! |
