radiator replacement
What radiators are you guys running? Looking to order one today.. Was thinking about a champion with an electric fan. I will be running a 355/4l60 combo.
Re: radiator replacement
I used a Champion from an eBay vendor. Great price and plug `n play fit. Integrated oil cooler but I left them plugged cuz I run a T5.
I put a us radiator in mine and it bolted in perfect. Have not started truck after install.
Champion here as well
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Not to hijack but which size did you go with? 3 or 4 core? I don't think the 4 cores will work without modifying the lower saddles??
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Also Bought the champion from eBay.
I will need to modify the saddles though. |
The OP question and replies made me remember the comments made in this post. I'm not saying Champion radiators are bad. I have an original Harrison radiator that I hope will perform well enough, but I think I'd go with a Griffin instead. It's good to have options.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Like the radiator with the side flanges forestb. I to am looking for a radiator. Called Champion and was told an EC284 will fit our trucks but I don't think it has the flanges on the side. I would have asked but i was at work at the time so I will have to call them back. Can any one confirm this or have a part number for a radiator with the side flanges.
Its a 3 core, been running it since 2009.
what radiator combo's are you guys running with 5.3 and 4L60e
Moderator
![]() ![]() Join Date: Aug 2011
It's good to know US Radiator has a nice unit for these trucks. I have used them in past hot rod builds.
I made a search of this site in the past and found a lot of us like the one from engeneered cooling products. I bought one too. Great radiator, good price. Ordered it online at speedcooling.com I did have to modify the lower saddles and the top mount is a tight squeeze but other than that no problems, and 20 degrees cooler than before.
#14 | |
![]() Join Date: Jan 2015
Thanks much
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
#15 |
I run the Champion, with electric fan and shroud bought on ebay for the last 3 years, and its been awesome. Never have over heating problems, even on the hottest of days.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
#16 |
What temp is preferable for a 350?
#17 |
#18 |
Lots and lots of opinions. Anywhere from 180-210 is what I find. Run my 327 at 195 for what it's worth.
#19 |
Griffin radiator and Lincoln Mark VIII electric fan...I like about 180 degrees
#20 |
Our premium setup: http://www.entropyrad.com/1963-1966-...-radiator.html
Our Driver setup: http://www.speedcooling.com/1963-196...r/prod_37.html
#21 | |
#22 |
Not if you use the eastwood radiator paint..it is thin enough to go on there without affecting the cooling
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com Last edited by Justin@EntropyRad; 07-01-2015 at 12:05 PM. |
#23 |
![]() Join Date: Dec 2011
we make made in the USA aluminum radiators, using domestically sourced materials. Each unit is TIG welded by hand, and we NEVER use epoxy or plastic in our rads. You can see feedback from customers on this forum, and ours are a direct fit and we never charge for building them to accommodate engine conversion (ie: no extra cost for LS ports, steam port, or built in trans cooler). We also offer a discount for forum members!!
http://67-72chevytrucks.com/vboard/s...d.php?t=591690 ![]() |
