![]() Join Date: Sep 2006
Motor mount dilemma need help
Looking for help on motor mounts I know this has been discussed over and over but I have dd plates but I am looking for what engine mounts I need to have, to ac mounted in factorty position and keep the motor in the factory location
Re: Motor mount dilemma need help
im guessing Dirty dingo sliders. me personally, I prefer the ac, to be mounted, up high, using an aftermarket bracket, for ease of service.
I don't think that I possible without notching the frame. I may be wrong though. What year truck is it going into. I used ict billet 551628 for my swap. They are billet aluminum, multi position and only $50. They also make swap brackets for the a/c. I think their prices are decent compared to others that I have seen.
Posted via Mobile Device |
If you can weld, put the motor where you want it. That's what I ended up doing with mine, because I wanted to keep the low mount a/c, but i refuse to cut my frame!
The mounts: http://67-72chevytrucks.com/vboard/s...7&postcount=74 Clearance pics: http://67-72chevytrucks.com/vboard/s...6&postcount=75
1965 Chevy C10 SWB Step (Family Restoration Project) http://67-72chevytrucks.com/vboard/s....php?p=6043410 1972 Chevy C10 LWB Fleet (factory auto/l6) http://67-72chevytrucks.com/vboard/s...d.php?t=580342 |
I used the factory rubber type mount with a Alan Grove low mount a/c bracket. It fits but you need to use a sanden type compessor. I think the poly type mounts are a little more compact and would provide more clearance. This was on a 70 GMC.
![]() Join Date: Dec 2013
I have some cpp poly mounts bnib if you need some
Jamie, what did you use for those frame mounts? Are they factory pieces?
#8 | |
New perch: http://67-72chevytrucks.com/vboard/s...0&postcount=66 You can see the unmodified mounts here: http://67-72chevytrucks.com/vboard/s...5&postcount=30 I installed them on the engine and marked to cut them horizontal with the floor: http://67-72chevytrucks.com/vboard/s...9&postcount=60 Then I just installed the cut mounts on the engine, set it on the new perches, adjusted the driveline angle, centered the engine, and tack welded the mounts to the perches. Once that was done I unbolted the whole kit and finished welding everything up. I could even elongate the bolt holes in the new perches and give myself about 1-2" of front to back adjustment if needed... Hope that helps!
![]() Join Date: Dec 2012
I used Early Classic Enterprises (ECE) LS conversion mounts and used the stock ac in the stock location. Not one issue a little pricey but when I test fit it it went in so smooth I didn't even have to take it back out. Of course this if for a C10
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Yes that does help. Thanks
Lee |
