Old 04-21-2015, 12:08 PM   #1
joe dirt
joe dirt's Avatar
wheels with or without nubs or clips...
Unsure what style to send to powder coat...left ones with the clips and no nubs...or right ones without clips but with nubs...i have both complete sets....
joe dirt is offline   Reply With Quote
Old 04-21-2015, 01:15 PM   #2
pimpston65
pimpston65's Avatar
Re: wheels with or without nubs or clips...
are you gonna use hubcaps? if so which style do you have? and use those matching rims!!! if you have both cap it docent matter, if no caps either will look basically the same...
pimpston65 is offline   Reply With Quote
Old 04-21-2015, 01:23 PM   #3
1963c-10
1963c-10's Avatar
Caps are easier to find for the nub style.....in my opinion.
1964 Short bed trailer
Old 04-21-2015, 02:04 PM   #4
joe dirt
joe dirt's Avatar
ya im leaning tword the nub style
Old 04-21-2015, 03:37 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
A couple other things to consider - the nub style are probably years newer than the clip style and may be in better condition. The nub style are "usually" welded together, while the clip style are frequently riveted together. This may or may not be a problem with future leakage. And lastly, the nub style may have "safety beads" pressed into the rim. I've never seen a clip style wheel with this feature. The safety bead is a depression in the rim that holds the tire on the rim if it goes flat. Early wheels have one bead on the front side. all newer wheels have safety beads on both the front and back of the rim.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-21-2015, 03:46 PM   #6
oem4me
As stated, the nub rims are easier to find caps for. If condition is the same, the hubcap factor should be enough to decide.
Old 04-21-2015, 10:32 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
disc or drums?
DPowers is offline   Reply With Quote
Old 04-21-2015, 10:37 PM   #8
joe dirt
joe dirt's Avatar
Originally Posted by DPowers View Post
disc or drums?
Im still drum...i dont plan on doing disc gor a while...drums are good enough for me
Old 04-22-2015, 01:00 PM   #9
OldGMJon
OldGMJon's Avatar
Wink Re: wheels with or without nubs or clips...
clip wheels are not disc brake compliant like the newer nubs are...
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 04-22-2015, 01:06 PM   #10
joe dirt
joe dirt's Avatar
nubs it is then,..thanks guys...on another note...im still unsure of color..i did a quick edit on my phone with a few combo's...top is how it is now with the full caps, middle is black with small caps,..and bottom is red with small caps...thay all look good in my opinion,..whats your take on the color combo?
Old 04-22-2015, 02:17 PM   #11
OldGMJon
OldGMJon's Avatar
top
Projects:
65' Chevy Panel swb
Parts:
Old 04-22-2015, 03:40 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
I like the top version best as well. I'm most curious about that unusual camper shell you have installed!
Old 04-22-2015, 03:47 PM   #13
joe dirt
joe dirt's Avatar
seems I was photo bombed by a mid 90's mommy missle
Old 04-24-2015, 08:04 AM   #14
duallyjams
duallyjams's Avatar
full wheel cover
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-24-2015, 09:41 AM   #15
The Rocknrod
Moderator
The Rocknrod's Avatar
Top
