04-22-2015, 07:52 PM | #1 |
HELP drop kit problems
My drop kit I ordered came in and am installing it currently, its a 5" 3" kit. Front went together well but im not seeing how the rear is suppose to work. The brackets don't make contact with under side of perch and im afraid it will not be centered or will walk. Help please and thanks
04-22-2015, 09:57 PM | #2 |
Re: HELP drop kit problems
I'm sure someone will chime but in the meantime do you have any pics?
04-23-2015, 10:30 AM | #3 |
Diggin The SquareLife
pics will help a lot....
04-23-2015, 11:30 AM | #4 |
04-23-2015, 04:06 PM | #5 |
04-23-2015, 04:13 PM | #6 |
its a crown kit off ebay. I really don't like how cheesythis bracket is but will due for now, im just wanting to know how its suppose to attach and align I guess
04-23-2015, 04:43 PM | #7 | |
is this on a c10? it looks like you have a c10 kit on a c30 (axle tubes are bigger) |
04-23-2015, 04:28 PM | #8 |
order new u bolts.... won't fix that issue but it will make life easier when you redo this.
04-23-2015, 07:51 PM | #9 |
I'd just do shackles and hangers then gets you a 4 inch drop. It's what I just did on my c30. I also removed the overload spring since I'm adding air helpers anyway and got it down another inch and installed new leaf spring centering pin bolts and u bolts wile I was at it.
04-23-2015, 07:59 PM | #10 |
Thanks so much for the help Scoti ill try to run up to Jegs after work or Saturday morning. Im new to these trucks ive always built trifives and pre 72 chevys
04-23-2015, 08:07 PM | #11 |
Whatever drop you have now would be the same w/a better quality kit. I would not run any flip bracket that is not reinforced under the axle tube (& why I suggest Bell Tech or Western Chassis).
04-23-2015, 08:25 PM | #12 |
Only way I can find it and have it fast is with buying it with the c notch, ill just use the c notch on a future project. I didn't look into the flip kit like I should have and those flip brackets look like flat stock I could have made in my vise.
04-23-2015, 08:35 PM | #13 |
What year/model are we talking about?
04-23-2015, 09:26 PM | #14 |
67-72 parts collector,…
04-23-2015, 09:28 PM | #15 |
This is the one I would buy.
(Western Chassis) http://www.summitracing.com/parts/ws...olet/model/c10 SCOTI is an EXCELLENT source of info.. I would listen to him.
04-23-2015, 09:37 PM | #16 |
I ordered the kit from jegs (belltech) no one has the basic kit with out c notch in stock. I need to get it on the ground this weekend and jegs says it will be here tomorrow . Ill use the c notch on my other truck later
04-24-2015, 07:11 PM | #17 |
Thanks for all the help, I ordered the kit with c section (only one they had on hand) ordered at 930 and was here at 3 today when I got home
04-24-2015, 10:23 PM | #18 |
04-25-2015, 12:18 AM | #19 |
trifiveshawn .. Please post pictures after the drop ... I'm doing an 1984 GMC and have been curious .. I have the same cheap flip kit as you started with ... Looks like I will be oredering from Summit as well ... Thanks & Good Luck !!!
04-23-2015, 09:54 PM | #20 | |
But..... many times, they will pad delivery times (under promise/over deliver). It's worth asking specific info on actual delivery times.
